Old 02-01-2014, 02:08 PM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Thanks for the photos Blake. Although the mounting bracket looks different, i do not think it was modified in mine or I can not think of a reason that required any modification.
Anyways I guess I need to flush out the ATF, don't know how though. Also a new rack and pinion maybe necessary
72 Camaro RS:SOLD
68 Camaro:
LS6 Engine,Tremec TKO 600,5 Speed
Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors, FIKSE FM5s
Old 02-07-2014, 11:05 PM
70 tt rustang's Avatar
70 tt rustang 70 tt rustang is offline
I would drain the reservior and fill with PSF. Run it for a few miles and change again
Old 02-08-2014, 01:32 PM
72Z/28's Avatar
Thanks man for the input, will do that
72 Camaro RS:SOLD
68 Camaro:
Old 02-10-2014, 11:07 AM
72Z/28's Avatar
Default Rack and pinion leak update!!
Ok guys I am going to order the 2GMP control valve as per Blake's advice. As for the Banjo fitting leak I did put littel force on the Banjo fitting, and it seems like it did stop the leak.
However, my concern is the leak shown in the first photo, apparently the black round cover is a plug to prevent ingress of dirt into the pinion portion. My interpretation might not be right and appreciate if someone could chime in to educate me.
With above being said, does it mean that a new rack and pinion needs to be installed or I can remove the black cover shown in the first photo and tighten the nut ( if there is one)
72 Camaro RS:SOLD
68 Camaro:
Old 02-10-2014, 11:38 AM
Blake Foster's Avatar
If I were you I would Call Mavel manufacturing and ask DIRECTLY.
talk to Marc Mercurio,800-338-9080 tell him I gave him your number.
Blake Foster
www.speedtechperformance.com
Old 02-10-2014, 12:34 PM
72Z/28's Avatar
Thanks Blake,I will give him a call sometime this week
72 Camaro RS:SOLD
68 Camaro:
Old 02-10-2014, 07:24 PM
Fyi dse has the flow valves in stock
Old 02-10-2014, 07:26 PM
http://www.detroitspeed.com/Steering...rol-valve.html
here
Old 02-11-2014, 05:59 AM
72Z/28's Avatar
Thanks man. The DSE control valve is applicable to PS pumps with integrated reservoir, whereas the Billet Specialities RP1300 is intended to be used with PS pumps with remote reservoirs.
I have remote reservoir so the Billet Specialities valve will be the correct one for my application
72 Camaro RS:SOLD
68 Camaro:
