Old 02-11-2014, 12:08 PM
67Rally's Avatar
67Rally 67Rally is offline
I posted a similar question on two other forums, and someone just posted pics of the Dynatech headers in a '69 Firebird with the recommended DSE mounts and 3* trans angle:
I don't have a good machine shop that I've worked with in the area. I'm going to swing by the exhaust shop later this week and see if they have any recomendations. If I mill my current flanges flat, I'll also have to dimple the headers near the PS box even nore in order to get closer to 3* on my trans angle.
Old 02-11-2014, 12:14 PM
OBeer-WAN-Kenobi's Avatar
If you did have to dimple them more it wouldn't be much unless the flanges are warped more than I'm thinking and they had to remove a lot of material. I haven't seen yours of course but I'd guess it would be less than 1/16" but you could also use a thicker gasket. I think they make thicker ones like they do for head gaskets.
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 02-11-2014, 12:27 PM
67Rally's Avatar
Yeah, sorry, I wasn't very clear with that thought.
I had two reasons for looking at new headers. One is to get the flange to seal, but the other is because I'm currently at a 4* down angle on the trans. In order to shim the trans up another degree, I'll have to dimple the headers yet again.
I'm happy with my ground clearance:
Passenger:
Driver:
But this is what I'm dealing with for clearance:
And here's what I had to do just to get that:
Old 02-11-2014, 12:33 PM
I see. What's wrong with 4° though? Are you getting some vibration or having trouble with angling the differential pinion up? I thought that 3°-5° was optimal? I haven't reached the part where I need to set angles yet but that's what I thought I read. Maybe I'm mistaken.
'69 RS Camaro
Old 02-11-2014, 12:44 PM
67Rally's Avatar
I think 2-3* is optimal. I had vibrations initially, but resolved them with 4* pinion angle shims.
I just swapped out my 12 bolt for a Strange 60 (Dana 60). Since I need to reset my pinion angle, I figured now was the time to try to hit 3* on the trans. I need to order a new driveshaft, but don't want to do that until I know exactly where my engine/trans will sit. I can adjust the position of my engine 2-3" forward or back because my engine mounts and trans x-member are both adjustable.
Basically I want to position the engine around the ideal header location, then set the engine/trans angle and pinion angle and order the right length DS. And only do it once.
Old 02-11-2014, 02:39 PM
Vince@Meanstreets's Avatar
what are the part numbers on these dynatechs? all the ones i have seen/used for 1st gens have that tube going up and over the box.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 02-11-2014, 02:53 PM
67Rally's Avatar
Vince, I'm not sure which post you're referring to. The top pic with the header's hanging super low are the Dynatech's and they are on someone else's '69 Firebird with the DSE mounts.
The one's I just post, those are not Dynatech's, they are the cheapo no-name ebay headers, Dirty Dingo Sliders, Energy Suspension mounts.
I'm trying to find a reasonably priced header that doesn't hang too low and has decent PS box clearance. I can move my engine forward/back 2-3" with the sliders and adjustable trans x-member, so I'm not locked into just one engine position.
Old 02-12-2014, 05:40 AM
rickpaw rickpaw is offline
Vince, the above is a picture of Dynatech headers installed in my 67 firebird with Hotchkis 2" drop front/1.5" drop rear. Dynatech p/n 715-11410, using DSE mount 060401. The ground clearance is 2.5" to the lowest point on the header.
Tu Ho
Old 02-12-2014, 08:40 AM
Blake Foster's Avatar
We @ Speedtech recently test fit our LS subframe headers into a stock subframe with the 6700 steering box. and they fir with TONS of room.
and the road clearance is the best I have seen. the header on the pass side is only 5/8 below the stock subframe. the drive side is about flush.
here are some pics. They are stainless and are 999.00 but they FIT.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Blake Foster
www.speedtechperformance.com
Old 02-12-2014, 09:13 AM
67Rally's Avatar
Blake, those look great! More money than I really want to spend right now with all the other projects going on. But do you have pics of how they fit around the PS box?
