Old 03-06-2014, 09:53 PM
6carmello8 6carmello8 is offline
Originally Posted by gnx7 View Post
Do a cam/dual springs/pushrods and rebuild the rocker arms with the Comp Cams trunion kit.
Brian Tooley Racing can custom spec you a cam and provide all these parts.
Get your throttlebody ported as well. Great bang for the buck.
If you have e85 in your area or can do a meth injection kit... get it tuned that way. 91 octane pump gas is garbage and can vary on octane levels for boost.
A cam actually makes waaaay more sense than heads for my goal not to mention that the stock Lq9 doesn't rev to 7K which I realized. This will help with a centri.
I'll do a preliminary set up with about 8-9 intercooled psi with 91 and with cams then later do a water/meth injection later with a few more psi if I need the power.
Old 03-06-2014, 09:59 PM
There's a 69' Corvair with a stock lq9 bottom end, ls6 inatke and a cam making 617 to the wheels! Granted it's running a D1SC but I talked to tech at Procharger and he said at the boost level I want ( 8 - 12 ) I won't see much of a difference (just a bit more mid range) going from a P1SC to a D1SC so I found out I have no reason to spend $1500 for a upgrade!
here's the link below if anyone's interested. Doesn't say PSI level but I'm guessing below 11...
http://www.dragzine.com/features/car...air-of-chevys/
Old 03-07-2014, 05:56 PM
Well, that's always good news. Save money and still making your goals. Good luck!
Old 04-04-2014, 03:51 PM
The T-man The T-man is offline
both
Old 04-04-2014, 09:53 PM
Sparks67's Avatar
Sparks67 Sparks67 is offline
Both Cnc heads and new cam..
Old 05-02-2014, 11:52 AM
Boris632 Boris632 is offline
i am very late to this party but if it is cam OR heads get the cam and do the springs.
The 317 heads work pretty good with FI.
google/youtube stock48 nova. A stock lq9 with a cam and a newer s476 turbo went 8.39@160+ in a Nova on pump e85 and a truck intake manifold.
He is pushing that motor hard but those numbers suggest he is pushing the 1000hp threshold.
So how much power did you want to make?
Old 06-25-2014, 09:36 PM
Wow thanks for the info. Had no idea the stock bottom end on the lq9 can handle that much power.
No upgraded rod bolts?
The tune must be incredible!
