Old 04-10-2014, 07:22 AM
MCPerformance's Avatar
MCPerformance MCPerformance is offline
Many people are helping put their .02 and that is what this is all about! I will be replacing the rod bolts, i will have pics and a little how to to add to the blog about my adventures in getting the short block ready. After talking to many people the stock cam is going to stay, bang for buck! if this project boneyard engine lets go we will be building an engine to drool on.
Muscle Car Performance
http://musclecarperformance.com
Old 04-10-2014, 09:22 AM
gearheads78's Avatar
gearheads78 gearheads78 is offline
Very interested in this. I have a 78 Suburban, drop kit, big in little ralleys and a 5.3 all patiently waiting to all join each other sometime later this year. A little boost would be iceing on the cake.
66 Cutlass "Joe-Touring"
54' Olds 88 "Joe-Touring 2.0"
69 SS Camaro 4-speed (wife's)
Richard J.
If only I had the time talent and money to build everything in my head
Old 04-11-2014, 07:16 AM
If everything goes well this weekend i will be putting the new rod bolts, setting the ring gap on the old rings and giving the block a fresh coat of paint. I picked up the heads from the machine shop yesterday. They went throught them and they were good! even the valve guides were good. so they did a valve job put new seals on and the new updated springs and retainers for them.
Old 04-11-2014, 07:37 AM
barrrf's Avatar
barrrf barrrf is offline
Good call on the ring gap. I would've never known to do this if it weren't for Project Big Bang Theory.
'69 Chevelle Malibu LSX370, 4L80E, Brembos, hydroboost, 12 bolt, c/os, etc.
You can call me Bart
Old 04-11-2014, 07:59 AM
Evan Iroc-Z Evan Iroc-Z is offline
Looking forward to see how you do the manifolds. I am currently build a junkyard turbo motor, 3800 series II vs. 5.3, but I will have cast iron manifolds to modify, with v-bands, as well. I have done plenty of research on how to do it but more is always helpful.
Good luck with the build.
'89 IROC-Z Turbo 3.8 5SPD
LS1 Brakes|Wilwood Prop Valve|LS1 Master Cylinder|Aluminum Driveshaft|LS1 3.42 Rearend|Adj PHB|Adj LCA|LCARB|Koni Struts|Koni Shocks|Adj Caster/Camber Plates|STB|10 Spoke SS Wheels|PHB Relo Kit|Adj TA|SFC|ARAP Based Prom|B&M Short Shifter|Underdrive Pullies|SMOG!|AIR!|Rag Joint!|Magnaflow|Ported Plenum|Misc Stuff
Old 04-11-2014, 10:03 AM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Even though it may have been done before this should be fun to watch/follow along!
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 04-11-2014, 04:57 PM
Thenovaguy's Avatar
Thenovaguy Thenovaguy is offline
Subscribed!
Old 04-11-2014, 05:48 PM
mitch_04 mitch_04 is offline
I always thought it would be cool to just take a regular junkyard engine, boost it until it something breaks. Then, grab another one, upgrade what broke and see what breaks next. Continue until you absolutely hit the limitations of the stock heads/intake, then upgrade those as well. You'd probably burn through a few engines, but it'd be cool.
They actually did that on an Ecotec in one of my turbocharging books. It was pretty interesting what they all did to keep it together. They eventually pulled over 1000 HP, no small feat on a 4 cylinder.
Old 04-12-2014, 12:13 AM
jeff71 jeff71 is offline
Are you gonna do a cost breakdown as you go?
Old 04-22-2014, 06:14 PM
astross89 astross89 is offline
cam or not. better valve springs are a must.
