Old 05-16-2014, 12:48 AM
69greyghost 69greyghost is offline
Originally Posted by LS1-IROC View Post
I think it would increase the overall value of the car, but not enough to cover the cost of the swap. While the LS1 motor is a little dated now, it's still a very capable motor as well as rock solid dependable. I think the LSx craze is till going strong and will continue to be a healthy market for years to come.
I would happen to agree, it will take some time for the aftermarket to build on the new gm platform and there is no guarantee that the performance to cost ratio will be as economical as an ls motor. I could be mistaken but I think cheap, powerful, fuel efficient motors could be something popular for a significant duration of time. Just my 2cents. I think I will stick with my ls1 until I get a reason to do otherwise.
Old 05-16-2014, 04:46 AM
hifi875's Avatar
hifi875 hifi875 is offline
Unless you want more power there is no reason to. It's still a ls. The design is the same. It's a ls. If you're happy w your ls1 then keep it in there and work on your brakes or suspension. So many poeple just throw a ls engine in and think they are done all the while they have stock brakes. Stock suspension stock interior. The engine is only part of a pro touring car and prolly not the most important part
69 camaro
03 z06
90 mustang coupe
1950 international l110
1993 mustang gt
Old 05-16-2014, 06:43 AM
n77nxc's Avatar
n77nxc n77nxc is offline
Originally Posted by Mkelcy View Post
The coolness of a 572 BBC is going to depend heavily on the price of gas, unless it's a total trailer queen.
It definitely would not be my commuter car for sure, and I think most wouldn't use it as such.
1967 Camaro - Project "Resale Red" - Sold to 175RGR
Old 05-16-2014, 11:48 AM
JKnight JKnight is offline
If I were in the market to buy a car, I wouldn't place a great deal of emphasis on what version of LS it is. If I know that the sub-systems are already in place for the LS platform, I know that I can always upgrade fairly easily at a later date. I would view the LS1 as being an indicator that the hard work is already done.
Old 05-16-2014, 05:16 PM
67Rally's Avatar
67Rally 67Rally is offline
Well, considering that most people that are swapping LS2/LS3's in to their cars are doing DOD/VVT deletes, you'd really just be picking up a few extra cubes (346->364->376).
For the money, I'd think you'd be better off rebuilding what you've got and boring/stroking it. If you've got the old 241's still on there, then maybe swap those out for some ls3 heads and a bigger cam with a decent intake.
Old 05-16-2014, 09:05 PM
Solid LT1 Solid LT1 is offline
The LS1 is a 24X EFI system......LS2/3 are 58X there's a lot more to the swap than just changing motors. You have a all aluminum V8 that can be modded and tuned to over 500HP easy.......I would be happier to know the car I was buying had a quality motor ( better rods/forged pistons/CNC ported heads ) than a plain crate motor.
Old 05-17-2014, 09:39 AM
charchri4's Avatar
charchri4 charchri4 is offline
Might be a few bucks in value in it but no way near what you will spend. I think it's kind of funny that guys feel the LS1 is dated when it's sitting in a 45 year old chassis. That and the 2 and 3 are the same "dated" family of engines.
Jim Stainer
No it's not a muscle car but it has a lot of muscle!
Old 05-17-2014, 09:58 AM
It comes down to the scope of the car. I wouldn't drop an LS1 in a high end pro touring car. The carpet has to match the drapes as the old saying goes. In an average Camaro, I'd take it over a 1st gen small block any day.
Old 05-18-2014, 08:33 AM
jwcarguy jwcarguy is offline
Banned
The LS3 heads are for a 4" bore or larger, not a option for a LS1
There are a aftermarket version "LS3 small bore" head, but smaller intake valves and big bucks!!!
Old 05-18-2014, 08:46 AM
Banned
IMO it would add more than "a few bucks in value", just for the simple fact that the larger engines (in stock trim) go for more than double the cost of a "LS1"
Also, the LS2 & LS3 are not the "same dated family of engines" (Gen 3 compared to Gen 4)
Both the LS2 & LS3 have:
-better pcm operating systems (58x )
- stronger bottom end rotating assemblies (coated skirt pistons w/ floating pins, larger connecting rods, stronger cranks)
- stronger block design and crankcase ventilation
- better flowing cfm(as cast) cylinder heads, w/ larger Intake valves
- VVT / DOD ( can be a benefit in certain applications)
- larger throttle bodies and better flowing intake manifolds
- larger fuel injectors
- improved lifter and tray designs
- stronger timing chains
- improved ignition coils
and the simple fact that they are larger cubic inches and make more power
hope that helps clear things up
Jeff
