Old 05-24-2006, 12:09 PM
4OfaKind's Avatar
4OfaKind 4OfaKind is offline
Question Ferrari Injection
Anyone know anything about this system? It is on a Ferrari F1 motor.
Is it a mechanical system or is it EFI? Could something similar be done on a street driven car? What are the drawbacks to fuel hitting the intake runners before hitting the valves? I don't know too much, help me out.
Mal
Old 05-24-2006, 12:35 PM
mazspeed's Avatar
mazspeed mazspeed is offline
First off it will not work, secondly why would you want something you can buy for a 5th of the cost and that would work on your car.
Old 05-24-2006, 12:58 PM
ProStreet R/T ProStreet R/T is offline
Just your typical F1 injection system, and yes they most certainly do work. But it's not even remotely feasable for a street vehicle. You would need a fully enclosed plenum and a fuel pump that can handle the required 700ish PSI (yes 700) of fuel pressure they run.
Old 05-24-2006, 01:04 PM
4OfaKind's Avatar
Thanks R/T
I was thinking along the lines of an enclosed plenum with a similar setup to hide the fuel rails. Make an efi system look mechanical. But I did not know you would need 700 psi to make it work! I did not want an exact F1 system, but someting similar as a way of hiding the fuel rails. Thanks for the constructive help, I'll go back to pondering.
Mal
Old 05-24-2006, 01:55 PM
Beach Cruiser's Avatar
Beach Cruiser Beach Cruiser is offline
Did you see that at the Ferrari Factory in Modena? I was there last fall and man, is it a motor heads dream. Got lots of pics if anyone is interested. I bet you would spend more money and Time that it could possiblly be worth, even if you did manage to make it work.
Old 05-24-2006, 02:59 PM
mazspeed's Avatar
Isn't that a overhead cam set up???
