Old 07-08-2014, 01:52 PM
Sieg's Avatar
Sieg Sieg is offline
......and after all that work.........oops!
Old 07-08-2014, 01:58 PM
Think of it as a big ol' birthday cake for freedom!
Obviously PRE 9/11/2001 -- and we'd just done the largest show in America for July 4th, 2000.... since 1976. I took this photo July 4th 2001....
Old 07-08-2014, 02:01 PM
Vince@Meanstreets's Avatar
And then my personal view of July 5th......
nice Daisey dukes greg. LOL
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 07-08-2014, 02:35 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Please don't fly over my house at 61' AGL.
........unless you tell me when!
To late!
Curtis
Old 07-08-2014, 02:40 PM
We had that happen to one barge in 1998 when the Pyro (Jose) on that particular barge didn't flip the switch on the firing box from 24V's to TEST mode... TEST mode would send down MILLIAMPS About 100 "cues" went off - it was on the 3rd and during the day - so we had time to pull shells from other barges and re-do/alter - the show so nobody knew it happened.
A brief explanation:
These large shows are shot using a laptop --- a "cue" (a line of code) can be 1 shell or multiple shells in multiple locations on set. Typical New York City show runs about 600 cues (which is, for that show, about 4500 shells). The laptop sends a signal to a firing box when it's time for the cue to light... the firing box sends 24V's to an electronic match called a squib... the squib lights the "quick match fuse" -- which then travels almost instantly (quick match travels around 100 to 300 feet per second) to the LIFT CHARGE -- lifting the shell to it's predetermined height. At the same time the lift charge goes off -- it subsequently lights a TIMED (slo-blow) fuse which lights off the detonation charge to light up and blow apart the shell.
What Jose didn't do was flip his firing box into test mode -- and a computer can count down 600 cues pretty F'n fast! Lucky for him - he realized what he'd done and flipped it -- saving most of his barge.
The Idiots in San Diego (this video) didn't know what to do.... and lit 'em all off... That's AMATEUR HOUR right there. Which is why only real pro's are usually running the big shows.
Here's a half shell showing the LIFT charge -- then you can see the timer fuse:
Where the red paper is covering the "quick match" --- we would tear off that paper covering -- slip a Squib inside -- fold it several times and seal it up with tape... The squibs have about a 6' two wire (zip wire) that we would then strip out -- careful place the shell into it's mortar.... and wire the squib to it's appropriate "pins" in the address box... large multi strand cables run from each address box back to the firing box.
In this photo -- the quick match is shown exposed. It WOULD NEVER BE exposed when done properly (thus the taping up after the squib is inserted).
Each mortar or "cake" is then capped or covered with tinfoil so as to protect it from accidentally being lit by the sparks and fire from a shell that was intentionally set off....
At the end of a show -- you knew when you had a live round (a dud or a good live round that just failed to fire) in a mortar because the tinfoil would still be intact! Then you got to look down the mortar --- and then reach in there and pull it out and put it away in a special box! That was the WORST PART EVER BEING A PYRO!!!! That SOB could go off without any warning and you're sticking your arm down that tube!! I hated that part. UGH.
WE always covered our racks and mortars with plastic until we got in to place in case of rain -- then we'd remove the plastic sheeting -- RAIN was normal in NYC at the end of June or in July... HOT and HUMID is the word for that part of the world in the summer.....
Old 07-08-2014, 02:46 PM
All my clothing - except shoes - was tossed in the garbage at the end of every work day.
Most of the mortars we used were steel - they get wet (takes 10 days or so to build a show) from rain or splashed on from being barged up the East River... they're rusty nasty POS -- now add to the mix -- spent gun powder.... little bits of paper from what's left of the lift charge... and SAND used to pack and secure the mortars....
Now add to this HOT AND HUMID heavy duty work.... which ='s SWEAT. ALL DAY sweating like a pig - and handling this stuff... We had a term for it -- it was called being CORN DOGGED..... you were covered in sand/paper bits/spent powder and rust...
Your clothes STUNK -- and were not to be tossed in any washing machine. They should have just been doused in gas and left to burn. The pay more than covered the expense of "new".
Old 07-08-2014, 02:53 PM
Sieg -- After jacking your thread -- did I mention that video was friggin awesome!! I sent it to all my 'works buddies in case they hadn't seen it.
I wish they'd do that for the televised shows like the Macy's Forth of July that I used to work. What a fantastic view!!!
Old 07-08-2014, 03:35 PM
cluxford cluxford is offline
I've seen one of these drones in action up close and personal....amazing what they can do and the video and pictures they get, and all for an incredibly low cost. I know a woman who works for the government who inspects houses where animal cruelty is reported. Historically it was a crap shoot if the visit would turn violent as not many people take kindly to that sort of knock on the door. Now she sits down the road launches the drone and does a fly over visual inspection first before taking it to the next step. They get some incredibly high quality very incriminating video
68 Camaro 632 BBC 800+ HP Project (600Kw)
61 Buick Lesabre Bubbletop (daily driver)......miles of smiles
Old 07-08-2014, 04:44 PM
intocarss's Avatar
They use this drone at our track in Ventura
Old 07-08-2014, 07:03 PM
Sieg's Avatar
To late!
Armed and ready..........61'..........got that covered! Probably a bit more lead than I'm used to applying though.
