Old 07-14-2014, 04:20 PM
Moose Moose is offline
Originally Posted by jwcarguy View Post
With your stock sub frame, you will have fitment issues with CTS-V accessory drive with both the alternator and factory a/c compressor (though you may not even be using that)
The CTS-V drive puts the alternator low on the LH side and unless you either move the engine forward or notch the frame, it will hit
May consider selling off the CTS-v drive and going to a Corvette accessory drive, which moves the alternator up top on the LH side
the factory harness would have to be modified to be a "stand alone" setup
A complete drop out engine & trans is not "ready to drop in" by any means
Or buy a new aftermarket harness that fits your application
You can decide then if you want to run the DBW (drive by wire) throttle body or switch over the a cable style (verify if the pcm that you are using has the necessary "drivers" to convert to cable TB (IAC and TPS are different circuits) can have a harness made to your needs
You can use your stock small block frame stands, but choose a quality set of engine plates/ mounts, ones that "work" with corresponding parts and don't cause fitment issues
The CTS-V oil pan will not fit your stock sub either, look at either a Mast or Holley conversion oil pan kit, (just for example)
Again, a good quality set of headers, that "work" fit the engine plates, oil pan and also the steering box that you are using
You can use the new stock fuel tank that you bought, but not the best choice and will take some work/ cutting to fit a retro fit elec fuel pump module (ie Aeromotive Phantom), due to your stock tank isn't recessed very much on top to accommodate the fuel pump
Look at a Tanks Inc EFI tank setup, stock capacity, powder coated, electric pump and sender is approx $450
The T56 from the CTS-V has a totally different tail housing/ output shaft setup, it does not have the traditional slip yoke, it has a 3 bolt flange (similar to a Gen 5)
Check with some reputable trans shops and see what the cost is to convert the tail housing/ output shaft setup, compared to both what you already have into it, if it needs to be rebuilt (recommended) and the value of selling it off and picking up a rebuilt LS/ F-body style T56 (outright Stage 2 rebuilt unit is approx $2400 w/ bell)
speaking of the T56, you should look into a quality (see the pattern here!) crossmember designed for this conversion
I am personally running the SpeedTech/ATS T56 crossmember and love it
I was around back when they first came out and still is one of the best crossmembers out there, you can give the guys at SpeedTech a call and pick one up along with their clutch master cylinder firewall mounting bracket
drive shaft will have to be made after rest of drivetrain is in place
and you mentioned wiring, if it still is the original 45 yr old wiring, replace it! Don't skimp on this, it is a safety issue!
I recommend the "Classic Update" kit from American Autowire "AAW" a few vendors here are even running specials on the complete kit, it does the whole car (still need a stand alone engine harness/ pcm though)
Please let us know if you have any other questions
Jeff
This guy knows his stuff!!!
Old 07-14-2014, 06:38 PM
69lsvert 69lsvert is offline
Yes he does. I'm willing to learn all this stuff and he's the man to teach me. If searched a lot on this and still am confused on it and I'm just gonna take it one nut bolt and wire at a time. This needs to be a sticky thread or whatever you call it at the top of the lsx swap page. But with so different cars and applications it would be a long one.
I bought my ls6 and 6 speed this morning and should get it towards the end of the week. I'm excited to see what Jeff was referring to as far as notching my frame for the accessory drive alt/ac. Mine was just done in fresh paint, oh well I've got more paint.
Old 07-14-2014, 07:06 PM
jwcarguy jwcarguy is offline
Banned
I only mentioned, that to use the accessory drive that you have from the CTS-V, that it may interfere with your stock sub frame and that some people notch the frame for clearance
I personally don't like to notch the frame for clearance, but rather go with a different accessory drive kit that fits your application better (ie Corvette style)
Especially if your frame is already done and painted, why go backwards
Granted, it is easy for me to say to buy a different drive kit and sell yours, since it isn't my money! LOL
These are some of the choices that only you will be able to make, given what your set budget and of course your skill set will dictate
Hope this clarifies things?
Jeff
Old 07-15-2014, 10:45 AM
OBeer-WAN-Kenobi's Avatar
On the accessory drive.
I used an 04 GTO takeout engine and transmission. I needed to notch the sub frame but for me, that was preferable to paying an exorbitant amount of money for a new drive. Accessory drives are unreasonably expensive for what they are, IMHO.
Also, look into Kwik Performance. They make brackets to mount your AC up high on the passenger side and make different alternator/power steering brackets as well. They're pretty competitive pricewise since you keep the rest of your stock drive.
Engine mounts, frame stands and headers are going to be the biggest PITA to figure out if you don't get it in "kit" form. There were 3 different frame stands in '69 and at least 2 different mounts. This will become a big deal as far as how high your engine sits and therefore how low your headers are going to hang and whether or not you will need to modify your transmission tunnel.
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 07-15-2014, 11:00 AM
Banned
I mentioned a GM Corvette accessory drive
They are very reasonable, as compared to the aftermarket accessory drive kits
http://www.jegs.com/i/Chevrolet-Perf...57325/10002/-1
Here is a pic of my personal 68' w/ Vette accessory drive kit
Old 07-15-2014, 01:05 PM
Definitely way better priced than a lot of the afermarket stuff, I totally agree. Plus, staying with stock GM that you can get at any stealership is really a good idea in general. However, even that kit is nearly $700 with the harmonic balancer though. Compare that to "free" (using the accessory drive you already have) and that's a lot of scratch you could use to buy headers or something.
If I didn't have an accessory drive (crate engine or what-have-you) the Vette drive would be high on my list. The high mount alternator is kind of fugly though. Not sure If I could get past that. On the other hand, my AC is high on my build and I got past that. Price and form/function over looks is usually my route.
Just for reference, here's the notch I had to take out. This should help with a decision either way.
https://lateral-g.net/forums/show...0&postcount=47
First picture in that post.
'69 RS Camaro
Old 07-15-2014, 04:58 PM
Thanks guys for all the info. Much appreciated!
Old 07-22-2014, 02:10 PM
Got my motor and trans in yesterday! Boy I'm gonna have lots of questions.
Old 07-25-2014, 03:29 AM
Default Conversion/swap kit
Ordered my install kit from Holley. Bracket kit to move alt and ac to top of motor instead of notching frame. Got motor mount adapters just need some motor mounts from 73 camaro to go with that. Got there long tube ceramic headers and transmission crossmember. Also got the Holley oil pan. I'm hoping it all fits together and goes in smooth. I'll let you know and post some part numbers later.
Old 07-25-2014, 08:07 AM
Taken from a PM, but thought it should be on the forum for others to find useful information...
Thanks for all the info. I decided to go with Holley on all my stuff, mounts, adapters,crossmember,headers, oil pan.
Now another question. All this is new to me so bear with me. The computer and harness what do I need to do with it. The guy at Holley said he had a comp and harness for 1750 and I passed.
You already have a computer (PCM) and a harness?
Do you want to tackle modifying the harness yourself?
If the answer to the previous 2 questions is "yes", then you have some decisions to make.
First, I'm not exactly an "expert" on this stuff. However; I just completed my build so it's fresh in my mind and I've learned about some stuff I'd do differently the next time.
So, think of all the stuff you want to eliminate. Most likely that will be rear o2 sensors, EVAP system, skip shift (CAGS). It's also mandatory to have VATS (Vehicle Anti Theft System) deleted or your engine will only run for a few seconds and shut off.
Second, think of what you'd like the PCM to control (Besides the engine). If you plan on using the PCM to control your fans for instance. What about the reverse lockout? Will you install cruise control? Do you want the PCM to control your AC system if you have it (Recommended for idle control).
After you've decided on that stuff, you will need to send off your PCM to a reputable person that can reprogram it for you (unless you want to buy $1K worth of software and learn it yourself). Work with this person and get everything fleshed out that you want. When he/she is finished they should be able to provide you with a pinout and a wiring diagram. I was able to get someone to do mine for under $300 which included a base tune for my modifications (CAI, 3" exhaust and LT headers). I would also recommend buying a second computer. I was able to get mine from a junk yard on car-part.com for about $25. This way you can have one in your car and send the other one back for tuning and you won't be dead in the water. Also, after all is said and done, you'll have a backup.
When you have the pinout, you can start modifying the harness. The first thing is to remove all of the loom and then to remove all the wires you won't need. After that, (and I learned this the hard way) wait until you install your engine and other components. At that time, decide where you want to put the PCM and lengthen or shorten wires as desired. You'll also either need to use the fuse and relay box from the donor car or buy one. I got this one from Current Performance:
http://www.currentperformance.com/Ac...ies/SA-1k.html
Basically, the above kit is the crossover from PCM and engine to your car. It's the piece that makes your harness "stand alone".
Doing this isn't exactly "easy" but it's not really as difficult as you first think. I was scared my first time doing this but now I wouldn't hesitate to do it again as opposed to spending $1k on buying it premade.
Of course, there is always the option to buy a harness from PSI, Current performance, Speartech or what-have-you. Even GM has their own kits you can buy now.
The bonus about working with a tuner is that they can set it up almost exactly how you want it. My PCM has partial code from a Savana Van, Corvette, CTS-V and GTO. All working to give the control I wanted. For instance, a GTO doesn't have fan control through the PCM, it uses the BCM (body control module) so the code that controls my fans is from the van. My AC fan control is actually from a GM prototype vehicle. I wouldn't have known the first place to start without my tuner.
You could just control the fans with a thermostat and the AC with whatever kit your using but it's way nicer to have the PCM take care of all of that and it makes a lot more sense from the engines perspective as it should idle up for AC for instance, and it already has a coolant temperature sensor, so why not use that for the fans? I like it as integrated as possible.
Anyway, it's a lot to think about. The planning is key. You really need to decide exactly how you want to do it.
For a perspective on whether you want to do it yourself or purchase something. I spent about $400 total on my PCM programming and harness modifications. I also put in about 20 hours of my time.
Hope this helps!
'69 RS Camaro
