Old 07-24-2014, 01:39 PM
Vince@Meanstreets's Avatar
Surrreeeeee it is. Haaaa
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 07-24-2014, 02:15 PM
n77nxc's Avatar
n77nxc n77nxc is offline
Wow.....
1967 Camaro - Project "Resale Red" - Sold to 175RGR
Old 07-24-2014, 04:55 PM
130fe 130fe is offline
Question
I have that same wilwood prop valve. How do you set it up (best place to position the dial before starting to try and fine tune it)? Any info would be appreciated. Never mind, I found it - http://www.wilwood.com/PDF/DataSheets/ds715.pdf
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 07-24-2014, 11:37 PM
Originally Posted by n77nxc View Post
Wow.....
I feel the same way. I like the engine to stand out more than the back ground.
What i like to do is.....ok.
Dealer for
NEVER FORGET -11
Old 07-25-2014, 05:31 AM
Motobrewmaster's Avatar
Motobrewmaster Motobrewmaster is offline
Here is the info that Wilwood gave me to setup my prop valve.
1. Set valve all the way open to 100% pressure flow (turn knob clockwise all the way until it bottoms out).
2. Turn knob counter clockwise (4) full turns, this is the starting point.
3. With an assistant outside of the car to watching the rear tires, run the car up to no more than 20 mph then get on the brakes aggressively (panic stop).
4. Based on the assistant’s observation, do one of the following:
· If the rear tires skid at the same time as the fronts, then pressure will need to be taken away by turning adjustment knob counter clockwise in full increments and repeat the run. Continue adjusting until rear tires no longer skid.
· If the rear tires do not skid, then turn the knob in clockwise to allow for more line pressure in full turn increments. Once the rear tires skid, go back and turn the knob counter clockwise in full turn increments until the rear tires no longer skid.
69 Camaro Owned since 1984.
Oh and Yes I am a Brewmaster.
Old 07-25-2014, 05:46 AM
n77nxc's Avatar
Good info! Thanks man.
Old 01-03-2015, 08:45 PM
Pete68's Avatar
Pete68 Pete68 is offline
Use a stock C5 set up. They are cheap on ebay. I did not nead prop valve, it was perfect as is. Plus with OEM parts you can still get parts for it in 10 years.
http://www.pro-touring.com/threads/6...r-67-69-Camaro
1968 Camaro
2003 Boxster S
http://www.cardomain.com/ride/2543199
