Old 04-16-2015, 01:03 PM
cjfirstgen's Avatar
cjfirstgen cjfirstgen is offline
Same transmission. The Super Magnum Kit includes the clutch, etc. Super references to the kit not the trans. The main thing you want to focus on is the T56 Mag has two gear ratio setups.
Use this:
http://www.tremec.com/calculadora.php
Project "Mercury Rising" '69 Camaro : https://lateral-g.net/forums/showthread.php4?t=41460
Old 04-16-2015, 01:45 PM
randy randy is offline
engine combo that i want
http://paceperformance.com/i-1590874...m-t-combo.html
t56 super magnum
The smoothest shifting, strongest, and most versatile 6-speed aftermarket transmission.
These Chevrolet Performance Tremec T-56 manual transmissions are truly brand new from the ground up. They can withstand up to 700 ft.-lbs. of torque, with gears featuring substantially increased face widths and 2-piece laser-beam welded construction, allowing for greater control of the tooth angles, pitch, and alignment.
Features:
•Exterior case similer to forth-generation F-body with stronger, high-capacity gear sets, input shaft and output shaft used in the Tremec TR6060
•26-spline input shaft
•31-spline output shaft
•Slip-yoke design
•40-tooth reluctor ring that's necessary for use with electronic vehicle speed sensors used with Chevrolet Performance controllers
•Kit includes shifter handle and Chevrolet Performance-logo ball-type shift knob
•New synchronizers featuring fine tooth angles
•Bolstered one-piece countershaft to resist distortion
•Re-designed shift forks
•An extensively modified transmission case to prevent leaks under high-stress conditions and increase overall power-handling capabilities
•Street - (1st-2.66, 2nd-1.78, 3rd-1.30, 4th-1.00, 5th-0.80, 6th-0.63)
http://paceperformance.com/i-2061895...nsmission.html
T56 magnum,
The kingpin of TREMEC's high performance line-up, the T-56 Magnum double-overdrive 6-speed transmission takes the very best from TREMEC's current OEM technologies and pairs it with the most popular features of the TKO 5-speed.
Able to withstand a massive 700 lb-ft. of torque while providing unbelievably crisp shifts, no other manual transmission on the planet offers as much combined strength, versatility, and general ease-of-use as the T-56 Magnum.
Known in its original equipment form as the 'TR-6060', the Magnum is an aftermarket version of the same transmission found in many of today's most celebrated factory super cars – including the ZR1 Corvette and ACR Viper – giving you refinement where you want it and strength where it counts.
Features:
•12 Tooth Reluctor
•Stronger input shaft
http://paceperformance.com/i-5160024...nsmission.html
two different part numbers
Old 04-16-2015, 01:56 PM
cjfirstgen's Avatar
t56 super magnum
T56 magnum, •12 Tooth Reluctor
The Super Magnum part # is a Chevrolet Part # while the other is a Tremec part #. I would think it is the same trans in the kit Tremec part #TUET11009 both with the 2.66 1st gear. Call them and ask. Tremec only makes the four part #'s I posted for the aftermarket T56 Magnum applications. That said the "kit" may be the OEM trans and not the aftermarket model which probably the only difference is the "kit" trans will not have the manual speedo output.
Most including myself go with TUET11012 which is the 2.97 1st gear but it depends on your gearing and tire combo you intend to run. Check that box first.
All the aftermarket Magnum's have both electronic and manual speedometer output.
Old 04-16-2015, 02:11 PM
goign to go with a ls3, rear tire is a 315/30/18, rear gear is 4.11 for now. Easily change out if need be.
https://lateral-g.net/forums/show...t=38891&page=3
this seems like everyone is going with the 2.66 gearing
Old 04-16-2015, 06:21 PM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
So im about to order my ls3 t56 kit from pace performance and the t56 is a super magnum .What really is the difference between the t56 mag and t56 super magnum? The kit comes with the super magnum but if i can piece it together and just get the reg mag and save money i would be happy.
Opinions please?
Also would you go with the ls3 430hp version and upgrade later with better parts or get the plug and play 480hp version right away?
Looks like you found the info, Randy. The main benefit is the reluctor ring which talks to the computer "better" than the regular Magnum and will offer the VSS output (to your speedo) within the GM harness.
We have a special going on for the Connect & Cruise packages, where you get the $500 savings off the front end instead of having to wait. Also a few bucks off of Pace's price.
Just thought I'd throw that out there!!
-Dale
SchwartzPerformance
Where classic style meets modern technology.
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 04-16-2015, 08:02 PM
68Cuda 68Cuda is offline
TUET11009 with 2.66 first gear for me too. I'm sure you saw it at the shop! My bell housing is a little different but the trans is identical.
No LS3 for me...
Michael
Plano, TX
1968 Barracuda Notchback
Body & Paint:
http://www.forabodiesonly.com/mopar/...dy-2014.10252/
Engine:
http://www.forabodiesonly.com/mopar/...ictures.10230/
Old 04-16-2015, 10:10 PM
-Dale
ok like how much $? same package and everything? Price me the 430hp version and the 480.
Old 04-16-2015, 10:23 PM
$11,800
http://paceperformance.com/i-1590873...m-t-combo.html
Engine and Transmission Package Includes:
• 19301326 LS3 430HP Crate Engine
• Chevy Performance Engine Controller and Harness
• Tremec Magnum 6 Speed Transmission(1st-2.66, 2nd-1.78, 3rd-1.30, 4th-1.00, 5th-0.80, 6th-0.63)
• LS7 HD Clutch & Pressure Plate
• LS7 Flywheel with bolts
• Chevy Performance Hydraulic Throw-Out Bearing with fittings & bolts
• -4AN male pressure line adaptor fitting
• -3AN bleeder line kit with speed bleeder fitting and mounting bracket
• Forth-generation F-body-type bellhousing with hardware
• T56 Driveshaft Yoke
• Chevy Performance LS Pilot Bearing
• Plug for speedo gear hole
• Back-Up Lamp Switch Pigtail Connector
• Pigtail Connector for Speed Sensor
• 1st Gear Sensor Pigtail Connector
• Lokar Chrome 10” shifter lever with white shift knob and shifter boot
$12,300 gm version plus $500 rebate
http://paceperformance.com/i-2068969...00-rebate.html
Engine and Trans Includes:
•19301326 GM LS3 6.2L 430HP Engine Package
•GM Engine Controller Package
•19329795 GM T56 super magnum Transmission with shift lever & knob
•GM Bellhousing, flywheel & clutch installation package
430 horse
376 cubes
24-month GMPP warranty
$12,250
• 19301358 LS3 480HP Crate Engine
• Chevrolet Performance T56 Magnum 6 Speed Transmission(1st-2.66, 2nd-1.78, 3rd-1.30, 4th-1.00, 5th-0.80, 6th-0.63)
480hp GM version $12,718 plus $500 rebate
I updated this to reflect the real differences and typos.
cps or GM version comes with the t56 super mag and the $500 rebate
pace version comes with the t56 mag and a lokar shifter and boot
Old 04-17-2015, 07:53 AM
OBeer-WAN-Kenobi's Avatar
Middle one comes with a $500 rebate?
I'd just call pace. Hopefully they can tell you the difference.
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 04-17-2015, 11:06 AM
Supporting Vendor
The $11,800 430hp price AND the last 480hp ones actually include a Magnum, not a Super Magnum. I called Pace to verify this. Typo.
The middle one has the rebate offering, and again the main difference with the Super is the 40 tooth reluctor that'd help your speedometer situation and integrate with the GM harness.
For the extra $$$ of the Super Magnum, that choice is up to you
MSRP on the Super Magnum is $4516 (Pace sells for $3878)
MSRP on the regular Magnum is $2995. So that's where most of the price difference is.
-Dale
SchwartzPerformance
GMachineChassis.com
LSxEngines.com
