					Originally Posted by skooli  If your Camaro is in decent shape, it would make a great budget auto crosser. Just get some stiffer shocks, maybe some sway bars, bigger brakes, better steering box, wheels and tires.
 I'm not sure what your budget is, but the parts I just listed should keep you under 5g's. You probably won't be beating Mary Pozzi around the cones, but you'll have a fun little car.
 If you're heart is steering towards another car, you can get 94-95 SN-95 Mustangs fairly cheap now too, and they are easily modded as they are still basically Fox Bodies wrapped in new sheet metal.
 i hate the 94 up Mustangs, just never liked the look. But yes you can defiantly get them cheap!
					Originally Posted by Rod P  That second gen is your best bet....the front suspension geometry is good you could keep the stock arms, just put in some good springs (front and rear) subframe connectors, quick ratio steering box, adjustable shocks and sway bars....done
 fox bodies are terrible in stock form...I just put one on the rack 3 weeks ago and the stock castor on that car was 2-3 degrees....in order to fix that will require a whole new autocross K-member with control arms (about 2500 bucks) and then subframe connectors, adjustable shocks and sway bars....done
 I get what your saying Rodney about the 2nd gen. I'm just looking for some ideas on something "cheap and fun"? I didn't know the Fox body was so bad, I had a very fast one years ago but I didn't take turns in it
					Originally Posted by Jr  2002 Corvette. |
 I've looked at some C5's but either they are junk or I get the "it's a Corvette"
					Originally Posted by Musclerodz  What are you considering for a budget? Your second gen would be cool and you already own it, but C5 vette can be had cheap and you can head to the track with a new set of tires. |
 Mike as far as budget I was thinking in the $6-7K range?? Which most likely either puts me in the Miata group listed above or just get the 2nd gen working nicely??
