Old 01-03-2015, 08:23 PM
Pete68's Avatar
Pete68 Pete68 is offline
I bought a C5 booster for my first gen on ebay for 150. Love it and relatively easy to mount. Had to cut the rod and use an early 70s Nova bracket to mount the booster to the firewall. Easy
1968 Camaro
2003 Boxster S
http://www.cardomain.com/ride/2543199
Old 10-26-2016, 04:39 AM
redfire69's Avatar
redfire69 redfire69 is offline
Exclamation
Originally Posted by Vince@Meanstreets View Post
The forth gen booster firewall mounts are different. The one to go with are the 2002-2008 corvette units. You may have to redrill the pedal or run a 1/4" spacer between the bracket and booster.
Or you can run the tuff stuff booster part number 2229NC
http://m.summitracing.com/parts/tff-2229nc
Works perfectly with the DSE reduced angle bracket
http://m.summitracing.com/parts/dsr-050302
You will also need the pedal clevis kit
http://m.summitracing.com/parts/sum-760125
Vince, I'm attempting this exact tuff stuff setup above on a former manual brake 69 Camaro. It looks like I'm getting interference with the booster hard rubber boot and firewall in the last inch of trying to bolt this up. Any ideas on this issue? Do I just tighten it down, or clearance the firewall hole, or ...? Thanks in advance. Ron
Ron
69 Camaro Redfire
Old 10-26-2016, 06:15 AM
1Bad68Cat 1Bad68Cat is offline
Originally Posted by 69greyghost View Post
Hey guys, I wanna run a gen 4 brake booster on my 69. My buddy told me to buy this dse bracket and thats all I need, is this correct? The info on the bracket says it only works with a special dse booster. Thanks guys let me know what you think.
I installed one on with friend's 69 camaro a few years back and on another after. I can't recall if all 4 bolts on the existing bracket match the firewall or if only 3 do. I can check when I get home. The one hole I know for sure that didn't match was the large diameter hole the push rod goes through. I welded the hole shut and redrilled it higher. I then mounted the pushrod onto the lower hole in the brake pedal.
Old 10-26-2016, 02:13 PM
redfire69's Avatar
Well it looks like I can't just tighten it down as this will cause a preload on the brakes. Anyone run into this with this popular combination?
Edit: I got some advice to clearance the firewall hole similar to the DSE setup. Will try that soonest.
Ron
69 Camaro Redfire
Old 12-12-2016, 08:01 PM
Vince@Meanstreets's Avatar
Sorry I missed this, some firewalls will need some metal moving. The manual cars have a smaller hole, depending on who was working that day.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
The Following User Says Thank You to Vince@Meanstreets For This Useful Post:
redfire69 (08-10-2019)
  #16
Old 08-10-2019, 08:45 AM
redfire69's Avatar
Exclamation brake line size
Des anyone know if it's safe to go directly with 3/16 brake lines off the master using this setup?
https://www.amazon.com/ACDelco-18M97.../dp/B000C9E5IW
Ron
69 Camaro Redfire
