Old 01-12-2015, 12:01 PM
Panteracer's Avatar
Panteracer Panteracer is offline
Default Dreamin Ta's
Decided to finally start a thread on my Firebird
I have owned this car for over 27 years
It was a $300 dollar non running Espirit
I changed the motor - 9 times now
made it a four speed car- now 5 speed
Twelve bolt rear end.. added bars and Konis
and started Autocrossing...
I added the Trans Am flairs, hood and Spoiler and
had one of my Autocross buddies Paint the Car
25 years ago for $1100... still looks pretty good
In the last several years I have added a bunch
of upgrades to the car
494 inch Mr-1 block, Roland racing head motor
solid rollers, shaft system now,.750 com cam,
scat crank, diamond pistons etc... was Popular
Hot Rodding motor but we replaced the valve train
and block to make it live.. original motor Dyno was
755 hp with 620 torque.. yes it is a Ponitac
Speed tech front end with coil overs - now Vikings
with 450 Lb springs
Mono leaf rear with spherical and raised front mounts
Viking shocks out back also
Protouring subframe connectors along with his old
Herb Adam style front braces, Autopower 5 point bar
Electric water pump, A1000 fuel pump with return to
Rick's SS tank with rear sump, Msd dizzy and electronics
Carb is a 4150 built with Dominator plate and metering blocks
approx 1150 cfm
Just put a Splitter out front, rear lexan window,
pulled the side windows and working on a rear wing
extension, have new side vents and a glass hood
to install sometime
Keeps me busy along with the Pantera
Bob
