Old 02-11-2015, 08:32 AM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
The 48 Hour Corvette will be equipped with a RideTech Level 3 Coil Over Suspension System.
Front Suspension Features:
Tubular StrongArms for optimized strength and proper alignment
Taller RideTech spindles optimizing camber gain for better handling
Billet steering arms eliminate bump steer and optimize Ackerman angles
Tru Turn steering linkage for proper steering geometry
StrongArms feature Integrated Caster Slugs for easy alignment
Delrin control arm bushings offer stable, smooth, and quiet bushing movement
Rear MuscleBar keeps the car flat with added tuning adjustable link mounts
TQ Series Mono-Tube Coil-Overs add tunability and improve ride and handling on the street and track.
Rear Suspension Features:
Tubular cross-member allows easy rear end removal and improves strength
Offset fabricated trailing arms offer more tire clearance and increased strength and durability
Relocated camber links optimize camber gain for better handling
Rear MuscleBar keeps the car flat with added tuning at adjustable link mounts
Old 02-11-2015, 08:36 AM
For those of you wondering about the powerplant…..
LS7 427 CID 650 HP 11.5 CRATE ENGINE with LS7 HEADS.
Lingenfelter Performance Engineering was founded over 42 years ago and is a globally recognized brand in the performance engineering industry. The company offers engine building, engine and chassis tuning components and installation for vehicle owners; component product development; services to manufacturers, aftermarket and original equipment suppliers; prototype and preparation of product development vehicles; late product life-cycle performance improvements; durability testing; and show and media event vehicles.
Lingenfelter LS7 427 CID 650 HP
11.5:1 compression ratio 93 octane fuel
• GM LS7 7 L aluminum block
• JE forged aluminum pistons high tensile 2618 T6 alloy
• Total Seal Premium file fit rings
• Callies 4340 forged steel Dragon Slayer crankshaft -58x reluctor
• Oliver 4340 billet steel 6.125 I beam connecting rods
• Clevite heavy duty HN rod bearings
• Federal-Mogul Speed-Pro heavy duty main bearings
• Lingenfelter LS 3 bolt cam conversion kit (L200175307)
• GM crank gear & HD timing chain
• Lingenfelter GT21 hydraulic roller camshaft (L210146006)
• GM LS7 dry sump oil pump
• GM keyed harmonic balancer
• GM LS7 lifters, lifter guides
• Corvette LS7 dry sump aluminum oil pan
• C6 Corvette valley cover, valve covers
• C6 Corvette rear cover
• Multi-layer steel (MLS) cylinder head gaskets
• GM head bolts, crank bolt
• Lingenfelter CNC ported & polished LS7 cylinder heads
• LPE Ferrea double valve spring kit (L230036006)
• GM LS7 2.205 diameter titanium intake valves
• GM LS7 1.615 diameter hollow stemmed sodium filled exhaust valves
• Competition Cams HD pushrods
• GM LS7 roller rocker arms, rocker arm stands, bolts
• LS7 Corvette composite intake manifold – fuel rails
• 90 mm throttle body, electronic
• 50 lbs/hr at 58 psi (4 bar) fuel injectors
• LS7 coils
• Magnacor spark plug wires
• LPE logo Koolsox wire protectors
• LS9 iridium spark plugs
• Lingenfelter Precision Built Engine certificate of authenticity
Component Preparation:
• All internal parts de-burred, hand washed & inspected
• Pistons, pins and connecting rods are pin fit
• Crankshafts – computer balanced to .2 grams per inch
• Chamfered oil holes & bearing surfaces micro polished
• Cylinder Block align hone checked / machined
• Precision honed on a Rottler HP6 with torque plates
• Hand de-burred, bolt holes are checked and re-tapped
• Cylinder heads precision 3 angle valve job to maximize flow & provide extended life
• CC checking chamber size for correct compression, surfacing to insure deck flatness
• Deburring, pressure testing, professional assembly, setting spring height
• Checking all tolerances
• Professional assembly & blueprinting
Old 02-12-2015, 06:05 AM
One of the major areas where any 1972 vehicle will need improvement is in the braking department. The 48 Hour Corvette is no exception… in fact it might be the poster child example for the too much go and not enough whoa.
With “tiny” oem disc brakes on all 4 wheels bringing this car to a stop can a challenge under “normal” driving and this car is destine to see a significant share of what most civilians would describe as “abnormal driving”. So clearly something has to be done.
Thanks to Baer Brakes, after the 48 Hour clock ticks off, the Corvette will be riding on some serious state of the art stopping power. When we contacted Baer, we were found out we weren’t quite ready yet to get the stuff on a brown truck heading to Jasper.
14″ Front Extreme+ Brake System
This system features the 6S 6-piston Monoblock caliper mounted to a 14″ 2 piece slot, drill, zinc plated rotor. Baer systems include stainless steel brake hoses as well as calipers that have D.O.T compliant dust and weather seals. Quality SKF or Timken bearings used, along with NAS high grade stainless hardware for our pre-assembled 2-piece rotor. The 6S and 6R (R-Spec) calipers are Baer’s Flagship offering, and are built out of a single piece of US sourced 2618 forged aluminum.
14″ Rear Extreme+ Brake System with Park Brake
This system features the 6S 6-piston caliper mounted to a 14″ 2 piece slot, drill, zinc plated rotor. Baer systems include a unique billet backing plate that not only acts as a caliper mount, but also houses the bankisa (1-piece) park shoe. This is a more modern (better working) park brake assembly then the more commonly used drum in hat park brake systems. Systems feature stainless steel brake hoses as well as calipers that have D.O.T compliant dust and weather seals. NAS high grade stainless hardware is used our pre-assembled 2-piece rotor.. The 6S and 6R (R-Spec) calipers are Baer’s Flagship offering, and are built out of a single piece of US sourced 2618 forged aluminum.
Why Purchase the Extreme+?
US Made Forged MonoBlock caliper
Offers the exact same look front and rear. Baer is the only brake manufacturer that offers this!
Calipers have dust and weather seals
Proper banjo fittings (NOTE: Baer does not use any pipe thread fittings)
Everything needed per corner (including hoses and fittings) except for in General fit applications
6061 T-6 billet aluminum hat (anodized black) and bolted to the rotor
High grade U281 fine thread stainless hardware (with captured nuts). Rotor comes pre-assembled.
Includes a set of 6061-T6 billet machined hubs with Timken or SKF bearings installed. Hubs are pre-assembled with bearings, races, studs and packed with Redline synthetic grease.
The 6S Extreme+ Caliper Features:
The 6S/6R monoblock caliper is Baer’s flagship offering, and machined out of a single piece of US sourced 2618 forged aluminum
The only 6 piston forged monoblock offered to the road-going/street market
Stainless steel pistons, abutments and noise suppression springs
Staggered piston sizes to minimize pad wear
Uses the common D1247 (DR11) race pad backing plate, that is shared by many other competition calipers.
Dual seals (dust/weather and pressure) to meet D.O.T specifications
Caliper can accept 13.5” to 16” rotors.
Machined logo that is hand painted
Red, Black or Silver Powder Coat Finish (custom colors available)
Available in Front or Rear for that same cosmetic matching look
Rear systems incorporate a drum in hat park brake
Rear systems for c-clip style axles include Baer’s Verislide self centering brackets
Uses correct banjo style fittings, Baer does not use any pipe thread
100% MADE IN USA with US sourced material
The Remaster is a fully machined, billet aluminum master cylinder that features:
Fully Machined out of aluminum in Phoenix AZ
Comes standard in Anodized or Polished (custom colors and finishing available for special order – additional charges apply)
Compact short design which allows this master to fit in a wide variety of applications (great for early Mustangs with modern boosters such as 1967-1969)
GM and Ford will use the same master (Firewall mount is designed to fit both). Will include a bullet (insert adapter) for long pushrod applications
Machined screw in caps for easy access to fill (no tools needed). Caps are knurled at edge to make removal easy.
Bolt on Firewall mount bracket. This master can be reused in other projects with a change of the bolt on bracket
Laser etched logos and part numbers for a finished look (on anodized version)
Bolt on proportioning valve block (additional option) is available
Old 02-12-2015, 08:52 PM
srh3trinity srh3trinity is offline
This should be cool. I love the shark Corvettes more than any other years.
Stephen
Old 02-13-2015, 05:05 AM
It should be a fun build, no doubt!
Old 02-13-2015, 05:06 AM
Magnum 6-Speed Transmission
The kingpin of TREMEC’s high performance line-up, the T-56 Magnum double-overdrive 6-speed transmission takes the very best from TREMEC’s current OEM technologies and pairs it with the most popular features of the TKO 5-speed.
Able to withstand a massive 700 lb-ft. of torque while providing unbelievably crisp shifts, no other manual transmission on the planet offers as much combined strength, versatility, and general ease-of-use as the T-56 Magnum.
Known in its original equipment form as the ‘TR-6060′, the Magnum is an aftermarket version of the same transmission found in many of today’s most celebrated factory super cars – including the ZR1 Corvette and ACR Viper – giving you refinement where you want it and strength where it counts.
The aftermarket’s premier 6-speed performance manual transmission
700 lb-ft. of torque capacity
Reasonably light at 135 lbs. dry
Multiple shifter locations & dual speedo pickups for unmatched versatility
Choice of two different gear ratio sets (2.66 or 2.97), with unique double overdrive ratios
Incredibly short, extremely low-effort shift throws, with crisp, precise engagement
Modern OE supercar technology for the ultimate pro-tourers, road-racers, and more.
Old 02-13-2015, 05:24 AM
67RSRAG's Avatar
67RSRAG 67RSRAG is offline
Hey Josh I am assuming the trans tunnel will have to be cut to fit the Magnum? which gear set are you going with?
Old 02-13-2015, 06:26 AM
andreb's Avatar
andreb andreb is offline
Those rear trailing arms are a work of art.
Old 02-13-2015, 12:29 PM
Smittys67's Avatar
Smittys67 Smittys67 is offline
The tunnel will need some modification. We will be running the 2.66 1st gear Tremec.
Chris Smith
Smittys Custom Auto
www.smittyscustomauto.com
Purpose Built Cars since 1999
Complete Turn Key Builds Custom Fab and Chassis shop
Dealer for Ridetech, Detroit Speed, Vintage Air, Billet Speacalties, Forgeline, Flamming River, No-Limit, SoffSeal, Wilwood, American Autowire, BeCool, Moser Engineering, MotorState and many more
Old 02-20-2015, 06:04 AM
Smitty's got your answer right here
Thanks! They came out extremely nice!
