Old 02-19-2015, 08:11 AM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
The completed front suspension
www.roadstershop.com
Old 02-19-2015, 08:26 AM
streetbird's Avatar
streetbird streetbird is offline
Very nice parts, make me want a c10
The French Frog
Old 02-19-2015, 08:27 AM
jy211's Avatar
jy211 jy211 is offline
looks great. What's pricing look like?
Old 02-19-2015, 08:45 AM
wiedemab's Avatar
wiedemab wiedemab is offline
How does the Panhard mount attach to the rear axle?...assuming you can use a stock rear-end.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 02-19-2015, 10:16 AM
Hugger67RSSS's Avatar
Hugger67RSSS Hugger67RSSS is offline
Any info you can give out on chassis stiffening that you have in the works? Looking at buying a porterbuilt one but will wait to see your plans. Thanks
Aarik
68 Camaro 6.0/T56, Jake's Rod Shop C6 Subframe, JRS Torque Arm, Ridetech TQ Coilovers
Old 02-19-2015, 10:31 AM
Nice looking piece ! I see a lot of guys wanting to give it some love in the future for their trucks.
Old 02-19-2015, 11:42 AM
Supporting Vendor
RoadsterShop.com
The completed rear suspension (with a few pieces of 1"x1" to prop it up for the pictures)
Old 02-19-2015, 11:47 AM
Supporting Vendor
RoadsterShop.com
The panhard mount is integrated to the driver side frame mount. The other end is a bracket welded to the axle tube. We had planned on selling this as a kit completely welded with a 9" housing and axles. If you wanted to use a stock 10 or 12 bolt, we can probably accommodate that. I would have to check some dimensions. I think the mount should be fine. The extra strengthening gusset may get into the cast center portion of the 10/12 Bolt housing
Old 02-19-2015, 11:56 AM
garickman garickman is offline
Amazing as usual. With this bolt on kit, how similar will the ride height be in comparison with your full frame trucks like the Craftsman truck or the original orange and white truck? What size tire can you run up front?
Greg
Supporting Vendor
RoadsterShop.com
On this truck, we are currently doing a simple trans crossmember and keeping the stock center crossmember in place. We have made a bolt on bracket that will act as an exhaust port in the stock center crossmember. We have plans for a more elaborate cradle style center crossmember in the near future.
