Thank you all. Nothing new to report, put a new door latch on driver's door of Vette the other day. Going to rebuild the Saginaw in the 57 and install a cross-member. Have a new poly bushing kit to install on front -end. Going to pull engine out and reseal/freshen her up a bit.
Once that project is done I have plans for a front 2" drop spindle/Wilwood disc brake conversion, updated tubular control arms, and adjustable coilovers.
When that's done I want to relocate my springs inside the frame in the rear so I can run a wider tire. Would also like to upgrade to the Wilwood disc brakes back there too.
Plan on attacking it slowly so I don't brake the bank.
