Old 06-19-2006, 09:59 AM
PaulV PaulV is offline
Originally Posted by 68RS350
As far as trunk pan patches they are available. Yout can buy the pan, the extensions and the ends. The 67 and 68's are the same. But there are full trunk pants that for from the tail pan all the way to the the rear seat. The 68 pan is not currently available. The 69 and 67 are. But the 67 does not have the staggered shocks. That is the only difference. If you wanted the full pant you would have to order a new shock tower and modify the pan.
68RS350, Thank you so much. This is exactly what they are telling me. The full trunk pans that are from the tail pan all the way to the the rear seat are not currently available for the 68.
Has anyone one the board modified this full trunk pan and used a new shock tower? Any Advice?
Old 06-19-2006, 10:00 AM
Originally Posted by ProdigyCustoms
You can get one through me, but I susgesst finding the closest Camaro parts dealer to save on shipping. Where are you located?
Do you have the FULL trunk pan?
Old 06-20-2006, 06:23 AM
68RS350 68RS350 is offline
What I would do is take all your measurements of your stock pan now. Purchase the full pan and then the LH shock tower. Id put the full pan in then cut out the LH Shock tower and place it in.
I checked Ricks First Gen and Classic Industries because I will purchasing a lot of sheet metal from them.
Rick's is $359.95
Classis Industries is $309.95
Also Classis Industries sells a Trunk Floor Replacement kit that has:
1 - Trunk Pan
2 - Trunk Extensions (LH/RH)
2 - Lower Side Panels (LH/RH)
2 - Floor Reinforcements (Optional)
$184.75 without the reinforcements
$256.50 with the reinforcements
