Old 04-16-2015, 07:28 PM
Vince@Meanstreets's Avatar
Originally Posted by DavidBoren View Post
The titanium exhaust will offer you no advantages over a stainless steel exhaust, other than being able to say you have a titanium exhaust.
The sound will be the exact same out of two identical systems, regardless of whether one is titanium and the other is stainless. So that fancy titanium exhaust you heard could be made in stainless steel for a third of the cost, and give you the same sound.
If you do choose to go titanium, for whatever reason, it would behoove you to buy it from a manufacturer, as I wouldn't trust your average exhaust shop to weld titanium properly.
As for mufflers, I like Borla.
Ti is a lot lighter. But dollar per lbs, you can do it else where.
As far as welding, Ti isn't much off, you just have to have the right gear. Cutting it, well that's another cluster. Stainless welds up a lot easier than Aluminum. I actually enjoy it.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 04-17-2015, 12:05 AM
omiotek omiotek is offline
Ti needs lots of gas flow and shielding
Old 04-17-2015, 08:44 AM
OBeer-WAN-Kenobi's Avatar
Sure Ti will have a different sound. The material properties are different so will have a different resonance. Is it worth it? Probably not. It sucks to bend and machine but not so much to weld IMO. It's most useful in aerospace and chemical applications that take advantage of it's strength to weight ratio and high chemical/corrosion resistance.
Ti does throw off really cool white sparks when you grind it though, gotta love that!
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 04-17-2015, 07:16 PM
yep, they use titanium dust in fireworks. Bright white flash.
What did you use to grind it?
Dealer for
NEVER FORGET -11
