Old 09-06-2015, 09:39 PM
dcrider69 dcrider69 is offline
Default What brake fluid?
Typical setup. Brand new, dry system.
69 camaro
6 piston wilwood front
4 piston wilwood rear
Hydro boost from hydratech
Wilwood master cylinder
3/16 front lines to 3an flex
1/4 rear line to distribution block to 3/16 hard lines to 3an flex
I really prefer something that is paint and powder coat safe. Thanks.
Old 09-06-2015, 11:24 PM
ilikeike's Avatar
ilikeike ilikeike is offline
It looks like you're familure with wilwood products.
Have you looked at their line of brake fluids ? They have a silicone fluid that you might safely spill on some finishes.
Old 09-07-2015, 06:19 AM
Motul 600 is what I use in everything.
Old 09-07-2015, 06:56 PM
I'm assuming that it's probably not paint safe, since I couldn't find that info during search.
Old 09-07-2015, 09:14 PM
It'll take the paint right off! LOL
Wilwood makes some high quality, high temp brake fluids too...
Old 09-08-2015, 05:50 AM
I will continue searching, wilwood shows a dot 5 that is paint safe. From what i have read, dot 5 is not a good choice.
