Old 10-04-2015, 03:55 PM
71RS/SS396's Avatar
Originally Posted by andrewb70 View Post
Don't the Gen IV sensors work differently than Gen III?
Andrew
Yes they do but you can use the gen III sensors with the extension harness I posted the link to.
Old 10-05-2015, 05:11 PM
instro84's Avatar
instro84 instro84 is offline
Originally Posted by 71RS/SS396 View Post
Buy one of these http://www.lingenfelter.com/mm5/merc...2#.VhEyi5cWYq4 and a flat valley cover ( can be found on e bay ... etc under knock sensor delete) and move them to the side of the block.
where on the side of the block would the sensors go? thanx
Old 10-06-2015, 03:36 PM
ilikeike's Avatar
ilikeike ilikeike is offline
I just bought the parts to do this myself.
I got the ACDelco sensors $38.75 ea. and a FelPro gasket $50.97 at Amazon.
Then thought I just go to the dealer to make sure I got a good genuine GM harness, paid around $30. I get home and look at it "Made In Serbia" Haven't seen that before, usually Mexico or Canada.
Might start on the project tonight.
Old 10-20-2015, 05:39 AM
IndyNova's Avatar
IndyNova IndyNova is offline
you cannot relocate the sensors on a gen3 block though, correct? I hate the fact that they're under the manifold and a pita to get too.
https://facebook.com/Protour69Nova
69 Nova-Ridetech, LS
Old 10-20-2015, 04:28 PM
71RS/SS396's Avatar
Yes you can, I moved them on my wife's LS2 to the side of the block.
Old 10-21-2015, 05:02 AM
IndyNova's Avatar
Is it as simple as getting the adapter harness and drilling and tapping the block? Or, do I even need the knock sensor?
Old 10-22-2015, 04:25 AM
71RS/SS396's Avatar
My wife's car already had bosses that were tapped on the side of the block but you could make a mounting block to screw the sensor into and use one of the existing tapped holes on the side of the block.
There's varying opinions on whether you need the sensors or not. Most tuners turn the sensitivity down once performance camshafts are installed since fast valve action tends to create more valvetrain noise which the knock sensors can see as detonation and the ecu starts pulling timing. How much the sensors are really doing at that point I don't know, but having them installed isn't really hurting anything so I prefer to keep them.
