Old 03-02-2016, 08:18 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Wow....a first for a product designed for a Chevy model other than a 69 Camaro! Would like more info on this product as I have a 72 Chevelle myself. This would make a lot of mounting made easy.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 03-05-2016, 11:19 AM
1965_SS's Avatar
1965_SS 1965_SS is offline
Would it work for a 65' chevelle?
_________
1965 Chevelle SS
Project Build
Old 03-07-2016, 03:56 PM
RPitts's Avatar
RPitts RPitts is offline
@ HPI this is exactly what I'm looking for for F body! Do you have a set up for behind glove box? Or a bracket to modify?
Rob 707-480-4881
Old 03-13-2016, 09:28 PM
SlowProgress's Avatar
Default GMPP ECM and Fuse Box Mounting 67 Camaro
My version. I didn't use the HPI clips but it would have saved me a couple hours of my time!
Old 03-14-2016, 01:21 PM
randy randy is offline
excellent work.
Old 04-11-2016, 07:27 AM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
Rob 707-480-4881
X2 HPI do you have anything for early F-body? checked your web store and didnt see anything
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
Old 04-11-2016, 10:37 AM
dhutton dhutton is offline
Hi Rich. I have a set of these brackets installed in the Cutlass. I think they could be mounted in an F body with some drilling and a couple of holes. Worst case you could use the DSE gas pedal mount instead of the HPI. At least that is my plan for the 69 convertible. You can drop by to check them out.
Don
Old 05-02-2016, 06:25 PM
Old66Tiger Old66Tiger is offline
Custom length Speartech harness allowed me to put the ecm behind the DS headlight. I also made a fuse panel with a cover to hide all of the wiring and fuses.
Old 05-05-2016, 04:49 AM
camarodude87's Avatar
camarodude87 camarodude87 is offline
Hello there,
great product! I was curious if and when will you be offering this for a 69 Camaro? My ECM is currently mounted in the glove box and I cant stand it! I want to purchase a vintage air kit one of these days and the ECM would probably be in the way. thank you so much!
Ray
Old 05-16-2016, 10:19 PM
partsguy57 partsguy57 is offline
Holley dominator ecu. My son milled it out of a chunk of aluminum and I replaced the ugly plate that came with the vintage air kit. 1st time project for him so not quite perfect on the centering of the holes, but not real visible so I told him I would run as is as he offered to mill another up.
Sent from my SM-G920R4 using Tapatalk
