Originally Posted by x-tream
How do you sugest lowering the car 2 or even more then 2 inches with wider wheels??
The pin drop on the Fatman and Heidt's spindle is the issue here, which leads to the inability to run a wide tire. Lowering a car with drop spindles as severe as these will cause outer tie rod/steering arm to rim issues. A factory or AFX spindle does not suffer from this.
Think about how low the attachment point on the steering arm for an outer tie rod is in relation to a factory spindle and pin height.
Now put that same pin 2" higher up on the spindle and that steering arm ends up well below the rim. Once you start getting wider than 6.5-7" you hit that attachment point. You can lower a car with springs and still go under 2" of drop and not have a wide tire issue. Take a look at CarlC's Camaro.
Originally Posted by 68RS350
They claimed it had 3 degrees of added caster. The guys at the alignment shop didnt believe me and I had to call them to verify. But its about 3 degrees.
Are you sure the alignment guys didn't use shims to set it at 3 degrees? The Heidt's arms are still no where near the three brands I mentioned earlier. Most have around 4.5 degrees of caster built in, with GW coming in at the highest with 6 degrees.
Tyler
