Old 01-14-2016, 07:07 PM
awr68's Avatar
awr68 awr68 is offline
Very nice! Thanks guys!
Tony
'68 Camaro
Old 01-24-2016, 10:06 PM
redss86 redss86 is offline
Does anybody know if the tensioner in the Alan Grove kit is their own design, or is it available elsewhere?
Not trying to hi-jack the thread. Just thought I would ask since you guys were talking about their brackets. I am trying to plan out my accessory drive setup, and am looking for parts.
Old 01-25-2016, 07:32 AM
TomM's Avatar
TomM TomM is offline
It's a GM tensioner......not sure if truck, car or what....
T,
Old 02-29-2016, 04:35 PM
kwhizz's Avatar
kwhizz kwhizz is offline
Here you go !!!................
http://www.ebay.com/itm/Dorman-419-1...VVxiuP&vxp=mtr
Ken
Old 04-23-2016, 08:25 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Will this bracket allow a 508 compressor to clear the stock frame on a 68 Camaro without notching it? I'm running the F-Body accessory kit on my 6.0L. Anyone know?
Chris
Old 04-24-2016, 11:32 AM
Chevy Kid Chevy Kid is offline
Short answer is no. It depends on where the engine is located.
I'm running the Holley system with the F body drive spaced 3/4" forward with a truck balancer. I made a custom bracket with a 7176 compressor. No notching but a 508 won't fit.
Tim
Old 04-25-2016, 10:07 AM
Tim
Hi Tim do you have any pictures of your set up?
Old 04-25-2016, 10:22 AM
kevin_l's Avatar
kevin_l kevin_l is offline
Wayne are you set on running a 508? I modified the alan grove bracket to work with a sd7 using a ems manifold. Fits very snug to the block.
Old 04-25-2016, 01:48 PM
I have a bracket to try to mount the SD7 close to the block. I tried it against the block and its hitting somewhere. I don't want to trim it someone is letting me try it for my car. I will be back in the garage this week after a cross country drive.
Old 04-25-2016, 03:55 PM
kwhizz's Avatar
Trim away..............
