Old 02-05-2016, 08:27 PM
Efi69Cam Efi69Cam is offline
Originally Posted by Sonar Chief View Post
Efrain ... I listen for the relay every time I start the truck, I don't turn the key until I hear the relay cut off ... it's always come on and clicked off!
I just thought of Auto Zone myself, I really need to leave it at the garage and let it sit overnight and then check the fuel pressure at the rail again.
Michael
I had one go bad, it would click, but had high resistance across the switched terminal. It's an easy check, swap it for another in the fuse box that's for a non crucial function.
Old 02-05-2016, 09:03 PM
Sonar Chief's Avatar
Thanks for the info ... I'll do that in the am and see what happens.
Old 03-19-2016, 01:15 PM
Just an update ... ordered a new relay (it's sitting in the glove box) filled the truck w premium gas and ran it on the highway to Denver and it's never acted up again .....hmmmm!
Old 04-12-2016, 02:15 AM
cjsgarage cjsgarage is offline
Michael,
Those throttle bodies get gummied up a bit too. I clean them with a rag and a little solvent and it makes a huge difference. Be sure to shoot some solvent through the idle bypass hole.
I like wiring. No joke.
Old 04-15-2016, 06:41 PM
Cool
Originally Posted by cjsgarage View Post
Michael,
I haven't touched it in quite some time, seems some good gas did the trick, she fires up like she always did ... no hesitation. I just made the trip out here to CA 1280 miles or so hauling the Camaro on a U-haul and she never missed a beat.
