Originally Posted by paulk68
so I spent some more time on this today and it is ugly. I mean i am almost an inch off from one side to the other. Is that normal?? am I really supposed to massage an inch somewhere in the sheat metal? I pulled out my level concerned the rails were off but that is not the case.
Here is the passenger side sitting where it should
And this is the drivers side
please help wish some suggestions. I get needing to go up a little but this is alot i feel.
Paul, From What I have found the problem is the angle of the forward supports (the last picture). I have cut and re-welded this section after the sides are flush. And it does help having up pressure instead of side pressure from the clamps. Drill then loosely bolt one hole and at a time this will help get all the holes to align. Do all the horizontal ones first then do the sides.
Another thing I have been doing is feeding a bolt into the frame and using a nut on the outside instead of the self tapping screws supplied. I have had customers strip them out checking for tightness. Works much better.
