Old 04-11-2016, 04:35 PM
jlwdvm jlwdvm is offline
I did have to change out my power steering pulley for another that game me more clearance at the upper A-arm. I also had to use an elongated pressure hose adapter to get clearance for the pressure line A/N fitting. I laid a straight edge across the balancer and compared it to the PS pulley...the pulley needs to slide on a little over 1/16" to match the balancer.
Old 04-11-2016, 05:08 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
That will cause that noise on a surp belt setup.
Old 04-11-2016, 06:27 PM
Well, I pushed the PS pulley on as far as I could go with out hitting the pressure line fitting. The alignment with the balancer isn't exactly perfect, but as close as I can get it with my combination of parts. I started the motor up and got it up to around 140 degrees with no noise at idle or when reeved up. Hopefully it stays away!
Old 04-11-2016, 07:49 PM
Che70velle's Avatar
Good for you! Simple fix is always good!
Thanks Dad!!
Old 04-13-2016, 07:32 AM
79 Camaro 79 Camaro is offline
I ran into a noise problem like this on my LS swap. I am using Fbody accessories. After the engine was warm I had belt noise. I replaced the idler, the tensioner and a new belt from NAPA. Thought it might be a bearing in the alternator but I had it checked and it was fine. The guy that checked the alternator said get a different brand belt. I went to Oreilly's and I think purchased a Goodyear belt and no more noise. Been great for two years now.
Old 04-14-2016, 08:19 AM
I ran the car up to operating temp the other day and I can still hear a little chirping at idle, but nearly nothing when the motor is reeved.
Old 04-14-2016, 11:10 AM
n77nxc's Avatar
n77nxc n77nxc is offline
Goodyear Gatorback belts are the best for removing noise. I have one on my 67, that had chirping issues. I was running a Gates previously. Also ran a Gatorback on my C6 vette with an A&A S/C.
1967 Camaro - Project "Resale Red" - Sold to 175RGR
