Old 05-09-2016, 10:18 AM
vstol vstol is offline
Air pocket if it goes from 210 to 240 quickly.
It does and I plan to elevate it tonight or tomorrow to see if I can get rid of it. Understand cap off?? Thanks
Old 05-09-2016, 01:33 PM
130fe 130fe is offline
Thumbs up
I agree with the air pocket diagnosis. Fill the engine through the upper radiator hose, and fill the radiator as well. Never had an issue with air pockets doing it this way.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 05-09-2016, 02:00 PM
Old 05-09-2016, 06:15 PM
randy randy is offline
even though my gauge was almost pegged out the engine never got to the correct temps to open the t-stat. Use the infrared scanner and check. I also squeezed my hoses to let air pockets out. It times time but you will be fine
Old 05-10-2016, 01:33 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
I also say air pocket. I've found my ls3 to be extremely sensitive to air pockets and somewhat tough to bleed whenever I'm refilling the system.
Steps I take now:
1. Jack the front of the car up.
2. Fill the engine first through the upper radiator hose
3. Then fill the radiator
4. Remove the 1/4 steam by pass line and ensure a steady flow of fluid (bleeding out last bit of remaining air).
5. Run the car with the heater bypass open and allow the thermostat to cycle with the radiator cap off multiple times.
Throughout the engine running and subsequent first cool downs ensure that the radiator level doesn't drop below the upper hose outlet at the waterpump.
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 05-10-2016, 05:44 PM
Thanks will try all of this tomorrow
Old 05-10-2016, 05:56 PM
sn75's Avatar
sn75 sn75 is offline
This may work for you as well (think some folks here and other site use this):
http://www.amazon.com/Lisle-24610-Sp.../dp/B001A4EAV0
I plan to use one when I eventually get my LS engine in my car.
Good luck
Old 05-10-2016, 09:34 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Stupid question, but you don't have tape covering the waterpump to block interface right? I've seen it happen before to a friend that painted his waterpump.
Also I've seen aftermarket waterpumps have the impeller on backwards, fall off, or just be missing all together if it's a stock style pump.
Old 05-11-2016, 03:51 AM
No tape, thanks. I plan to attack this again today
Old 05-11-2016, 07:34 AM
I have the car elevated but not to the moon. I have started it twice and see the bubbles, this time the upper hose is warming up as is the radiator water but the temps still pass 210 and lower hose cold. I do not let it go past 210
