Old 07-14-2016, 01:24 PM
dhutton dhutton is offline
Originally Posted by Moose View Post
Thanks Don, I'm far from a expert on this, appreciate the advice.
Other thing is make sure you always have more or equal sidewall in the rear compared to the front.
Don
Old 07-14-2016, 07:46 PM
carbuff's Avatar
carbuff carbuff is offline
so Im reading this, and in the market for new wheels and tires for my car.
I checked tirerack, discount tire, amazon and a few other places and the only 335/30/18 tire I can really fine are the Nitto Drag radials..
I was hoping to get the BFG's rivals, but they are back ordered every where I look..
Should I go with the 19" wheel for better tire selection? 335-25-19?
sorry to hi jack 69 hugger
Why do you want the 335? Performance? Looks? Because it's the cool thing to do? ;-)
Seriously... Our cars are generally front-end limited in terms of handling capability. If you are targeting handling, getting a bigger front tire is probably the better option. I run 315's in the rear, and I'm trying to squeeze a 315 up front to match it.
The "high performance" tires are hard to find the in 19" sizes as well, so that's not a magic bullet either...
Good luck, it's hard to find the right balance...
Old 07-15-2016, 04:32 AM
Moose Moose is offline
my car sees some autocross, but not a lot.. twice a year at best so far. I'll be putting a 275 on the front, about the best I can do on my budget.
Old 07-15-2016, 06:20 AM
dontlifttoshift's Avatar
You're right but there are a handful more choices for wide 200tw 19s than there are 18s. RS3, RE11, PSS, NT05, to name a few, and on August 2nd the 305 RE71 should be available. Out of those, the only tire that runs with the RivalS is the RE71.
Donny
Old 07-18-2016, 04:36 AM
69hugger's Avatar
69hugger 69hugger is offline
Just to recap (pun intended) I am looking for a street tire, NOT a semi-race tire. I have Rivals, & they are killing my paint. I have clear mask material on the lower 6" of the car sides, but above that I get chips almost every time I drive the car. I want to go back to Pirellis or Michelins, or ??. As far as size, I currently have 335/30-18's, and want to stay with them or a slightly narrower & taller size.
If anyone has a pair of the above or knows where I can locate a couple, I'd appreciate the heads-up.
Bill
Bill
'69 Camaro / 534 BBC / DSE Built
'67 C10 / LS-3 w/Magnuson / Roadster Shop Chassis (SOLD)
'71 Blazer / LT4 / 8L90 / Roadster Shop Chassis / Ride Tech Air Susp.
Old 07-18-2016, 04:29 PM
Bill
Tirerack.com has 335.30/18 pirellis p zero system max performance summer tires.. it said 3 in stock on web site.
Mike
Old 07-19-2016, 03:58 AM
69hugger's Avatar
Thanks Mike. I did see that, but...
A.) When I enter my zip code, it says the are on B/O, special order is available is available with no delivery date offered.
B.) The Rossos are priced at $470 ea., which is bad enough, but the P Zero Systems are $622 ea, plus freight. I'm having a hard time swallowing that price.
Thanks for the suggestion.
Bill
Bill
Old 07-19-2016, 11:44 AM
Panteracer's Avatar
Panteracer Panteracer is offline
Default 335 tires
Donny,
How do you know Bridgestone is making a 305 tire in the RE71R?
Anything else bigger?? Love that tire and with 285's the biggest
it seems like they should make something bigger
I agree more grip out front is better
I had to reduce the size of my tire on the
rear of my Pantera to get the push out of it
as I am limited on what I can get up front
Going bigger on the front of my bird but need to cut the fenders
Bob
Old 07-19-2016, 12:17 PM
carbuff's Avatar
I've been reading rumors about this tire coming on the Corvette Forums for a while. I cannot recall whether it has been confirmed for certain, but what I have read is that there were not plans for any larger size than the 305... That is all subject to change at the manufacturer's whim of course.
