Old 07-29-2016, 06:46 PM
DT69Cam DT69Cam is offline
Originally Posted by dhutton View Post
This Bosch 12V 30A relay has a coil current of 160 mA which is a lot more than an LED.
http://www.texasindustrialelectric.c...0332209150.asp
I will dig around and see if I can find the CEL current capability.
Don
Thanks Don !!!! So the Bosch relay may work ??
69 Camaro Convertible (LS3/TKO in the works)
Old 07-29-2016, 06:55 PM
dhutton dhutton is offline
No I think it requires considerably more current than an LED and as such it may not be able to sink enough current to turn the relay on.
This is all I could find regarding MIL current capacity:
This circuit requires any 12v low current light and an ignition 12v power source. The ECM MIL output supplies the ground for the circuit.
I am not sure that 160 mA would be considered a low current light.
Looks like all you can do is try it and see if it works. Sorry I could not be of more help other than raising questions.
Don
Old 07-29-2016, 06:58 PM
Don
Hey, thank you very much !!! FYI Don, I'm also over on Team Camaro. I asked the same questions over there LOL. Thx again.
Old 07-29-2016, 07:10 PM
How about this little solid state relay? If I am reading it right you can use a positive or negative trigger. Just connect the negative trigger input to the MIL signal and add a 4.7kohm pull-up resistor to 12V. Then use the relay as you had planned.
http://www.ebay.com/itm/1-Channel-SS...QAAOSw4SlV8f4-
Don
Old 07-29-2016, 09:44 PM
randy randy is offline
why can't you just give the light constant power and hook the ground to the check engine light wire? Thats what i did
Old 07-30-2016, 05:22 AM
130fe 130fe is offline
Post
Don, just curious. The picture I saw on New Vintage's website showed a CEL in the right side gauge. Why not use the one already built in? Are you 100% sure that the CEL requires the POS signal? Just seems weird that the industry standard is a Neg signal from the PCM and New Vintage is totally different. Just seems like alot of trouble to go through for the light to work.
http://www.newvintageusa.com/images/69-set-lit.jpg
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 07-30-2016, 05:30 AM
Yep, that's the one. It calls for 12V positive.
Old 07-30-2016, 05:32 AM
For whatever reason the gauge wants a positive drive for all the indicators. Both LED pins are not brought out, only the positive side as far as I know. Why they didn't do their homework is a bit of a mystery. There may even be a controller between the input signals and the LED's.
Don
Old 07-30-2016, 05:33 AM
Because you don't have access to both LED pins.
Don
