Old 08-22-2016, 07:29 AM
I'm with Greg, I'd be checking the installation of the coil over brackets to see if they establish the correct mounting height.
Old 08-22-2016, 07:49 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
The are no coilover brackets. Bottom mounts to DSE lower control arm and top is through original hole in subframe.
at this point im leaning toward the sway bar binding
Old 08-22-2016, 09:56 AM
dhutton dhutton is offline
Looks like DSE no longer uses the weld in conversion brackets. Coilover spring uses the upper coil pocket and the shock mounts like the stock shock.
http://detroitspeed.com/1967-1969-F-...lover-kit.html
I didn't know they had made this change. Nice thing is the coilover is no longer upside down and you don't have to bust the ball joint pull the coilovers to adjust ride height.
Don
Old 08-22-2016, 10:33 AM
Blake Foster's Avatar
we have see with the Hybrid coil over that when the shock pin is used as the mount that the shock body will hit the factory spring cup up in the subframe. there for making the suspension solid!!
the factory cup was not designed to fit a shock of that diameter.
Blake Foster
www.speedtechperformance.com
Old 08-22-2016, 01:14 PM
Build-It-Break-it's Avatar
I wish Detroit Speed would take the time to help with this. I NEVER see them on here helping customers with their product. It's always another vendor.
Customer service after the sale.....
Ahmad B
Old 08-22-2016, 01:15 PM
bret's Avatar
bret bret is offline
Supporting Vendor
loosen the control arm bushings. Sounds like the bushings were tightened with a 3/4" impact wrench. Even Delrin bushings can be made to lock up when tightened way too far.
Beyond that...pictures of the spring at ride height with the full weight of the car on them] might help
Bret Voelkel
President
RideTech
Air Ride Technologies, Inc.
Old 08-22-2016, 01:24 PM
Vega$69's Avatar
Not ever been able to get a hold of DSE easily.
So far I detached the sway bar. The bar is so tight in the bushes you can rotate it by hand. I'll drive it with the endlinks detached to see if ride ir like it should be. If so I free up the sway bar and the control arm bushes.
Guessing the were never greased.
Hope it's all that simple to resolve,
The rear also rides hard with DSE Leafs. I pulled the KYB Gas Shocks as in my experience they will make for a harsh ride. Picked up some Gabriels to try.
Old 08-22-2016, 01:47 PM
NvrDun71 NvrDun71 is offline
DSE's instructions say to clearance the upper shock pass thru opening in the upper subframe spring pocket. This could be part of the problem if that step was skipped, as Blake mentioned above
71' Nova - LY6, T56
Old 08-22-2016, 03:16 PM
bret's Avatar
Supporting Vendor
That is why we developed the delrin swaybar bushing liners for the StreetGrip swaybars. Depending on the diameter of the bar, we may be able to convert your bushings. Makes a big difference. That resistance you are feeling is extra induced spring rate.
The KYB units are typically heavy on compression valving...which makes a harsh ride quality. We can fix that too
Bret Voelkel
President
RideTech
Old 08-22-2016, 03:51 PM
GUYS!!! Pay attention here!! This vendor took his time to help out a problem on another vendors products.
I LOVE YOU BRET!
