Old 09-04-2016, 11:15 AM
vstol vstol is offline
interesting where did you purchase the phoenix unit
Old 09-04-2016, 06:58 PM
dhutton dhutton is offline
eBay. I think this is the one I have:
http://www.ebay.com/itm/Phoenix-Syst...3D162056873876
Don
Old 09-05-2016, 04:23 AM
thanks
Old 09-05-2016, 06:37 PM
JUSTANOVA JUSTANOVA is offline
Originally Posted by andrewb70 View Post
You would be surprise how much fluid it takes to fill new, dry brake lines...I would just crack all the bleeders and let gravity do the work while keeping an eye on the fluid level in the MC...
Andrew
I do this method especially when dealing with all new components, crack all bleeders, and keep the master topped off, wait for fluid to come out of all the bleeders (sometimes this takes a while, I have had it take a half hour plus) then close all the bleeders and do the normal brake bleed procedure to be sure.
Project EARTHQUAKE:
72 Nova SS, Plans have changed a little:artmorrison front subframe, and rear 3 link, pretty much stock ls1 and six speed with a single turbo for around 550hp. with a few other things mixed in.
current cruiser: "The green machine"
'70 Impala 4drht, 26K original miles, 2" drop springs and large swaybars, drives pretty good for a land yahct
and why do we modify everything...."BECAUSE STOCK SUCKS"
Old 09-06-2016, 04:24 AM
thanks
Old 03-19-2017, 03:40 PM
Well finally back up with the car after building an addition to my home. Went back again to bleed my brakes and nothing in the rear. The Wilwood master brake cylinder was bench bleed and also bleed while on the vehicle. It is not pushing the fluid so I am thinking I need to back out the threads in order for it to completely clear the rear return/orifice in order to get the fluid to the rear. I am getting fluid to the fronts. I plan on calling wildwood tomorrow but keep you ideas coming. Thanks
Old 04-20-2017, 03:00 AM
Problem solved and not sure why, thanks
