Old 11-23-2016, 08:59 PM
69Camaro's Avatar
69Camaro 69Camaro is offline
Originally Posted by Musclerodz View Post
I just finished a 67 Camaro with full ridetech suspension, tru-turn, with forgelines and 265/35-18 bfg rival up front, no rubbing. I am running 1 degree of negative camber as well.
I'm ordering Forgeline GA3's very soon for my 69 Camaro with tru-turn and the Ridetech level 2 suspension. What backspacing and wheel size did you use? What brake package?
Thanks, Jayson
Old 11-23-2016, 10:22 PM
Musclerodz's Avatar
Thanks, Jayson
18x9 with 6.125 bs I think. Have to double check. Wilwood 14" aero brakes. I can quote all of it if you wish. I am direct top level dealer with most all the manufacturers including Ridetech, Wilwood and Forgeline.
Mike Redpath
Musclerodz & Customz
facebook page
Old 11-24-2016, 03:08 AM
paulk68 paulk68 is offline
ugh I was all set on a 5.5 front back spacing per ridetech recommendation. seeing 6.125 makes me rethink it all. I am running the baer pro + brakes.
Old 11-24-2016, 04:56 AM
dhutton dhutton is offline
I used 8.5 with 5.5 backspacing on my wife's 69 so Mike is pretty much spot on for a 9" wheel. When you go wider you have to push it in further. Not sure why this makes you rethink everything...
What width of wheel did Ridetech specify for the 5.5 back spacing?
Don
Old 11-24-2016, 06:18 AM
Don
Don thanks again for all the guidance
I specifically asked about a 18x9 wheel and they said 5.5 BS would be perfect.
Old 11-24-2016, 06:26 AM
Based on my 8.5 with a 5.5 backspacing I would go with Mike's number. I think it would rub otherwise. Either that or you will need a lot of negative camber.
Don
Old 11-24-2016, 08:36 AM
69Camaro's Avatar
PM sent
Old 11-25-2016, 05:50 PM
Musclerodz's Avatar
PM sent
replied
Mike Redpath
facebook page
Old 11-25-2016, 06:11 PM
Musclerodz's Avatar
here is a pic of the 67 I am referring to.
Mike Redpath
facebook page
Old 11-25-2016, 07:04 PM
What's more important: No rubbing? Every ounce of performance?
Suspension tuning, alignment, and driving skill will make a much greater difference than 10mm of tire. The only reason I know this and say this is, I graduated from the 1-800-get car help class for car addicts.
