Old 02-18-2017, 01:30 PM
Brewtal66 Brewtal66 is offline
Originally Posted by mitch_04 View Post
Hope it works for you. Visually, they aren't like the older gaskets which are usually an obvious blowout. The section will just be a little flatter and may have a slight discoloration. I've replaced oodles of them and rarely is it an obvious leak. Our smoke machine makes it an easy find, otherwise they can be very difficult to diagnose.
It's been almost two weeks and hasn't done any of the rough idling. I'm fairly certain it was those gaskets.
I don't have a smoke machine, but it was only $17 bucks for gaskets and a little over an hours work, so I rolled the dice. It would have been nice to use a smoke machine just to know for sure that was the issue though.
Now I'm thinking my truck(2000 5.3L) might need a new set as well. Sometimes it studders a bit when first starting up.
Editor, Lateral-G
[email protected]
Old 02-18-2017, 02:52 PM
mitch_04 mitch_04 is offline
I think I have smoked roughly 30-50 of them, and only 2 haven't needed gaskets. If you know someone who smokes, just have them puff one into the fuel pressure regulator vacuum line. Not quite as efficient as a machine, but usually will do the trick. Then again, for $20, it's hardly worth it. They are so easy to do.
Keep an eye on your knock sensors and harness, they often break the wire right above the seal. I usually pop the seal and wire off, the rear sensor is often corroded and prone to failure. Of course, you can always just pull the intake again if they go out.
