Old 02-22-2017, 04:15 PM
randy randy is offline
Brian drove it around again today with gas alittle lower. You can still see some coming out of it. I noticed whenever i removed my gas cap it released the pressure and stopped. Sounds like i need more venting.
Any ideas where to run the vent line too if you connect it on the ridetech filler neck?
Old 02-22-2017, 07:33 PM
I'd start to the same vent tank and go from there. My guess is your problem is inside the gas tank, not the breather tank.
Old 02-22-2017, 07:37 PM
huh?
Old 02-22-2017, 07:38 PM
What gas tank are you running?
Old 02-22-2017, 09:31 PM
Ricks tanks, notched corners, with camaro fuel pump
Old 02-23-2017, 09:03 AM
The vent tube size inside your tank may very well be your problem. Your ride tech vent will aid in relieving the tank pressure. You may be able to vent it right to your current breather tank.
Old 03-02-2017, 09:26 AM
JohnUlaszek JohnUlaszek is offline
Would need to know more about your setup, but I am sure we can help you sort this out. Give us a call at 888-216-6033.
Old 03-13-2019, 10:30 PM
sd67 sd67 is offline
Did this ever get sorted out? I am looking at the II much vent vs the Finch unit. I have the same set up - new Ricks tank with Camaro pump.
Old 03-13-2019, 11:28 PM
Mine hasn’t done it since. It’s not the finch issue it’s the ricks tank having the vent port so low on their older tanks. My new tank will be higher. Don’t worry about it just buy the finch setup and install it
The Following User Says Thank You to randy For This Useful Post:
sd67 (03-14-2019)
  #20
Old 10-15-2019, 07:51 PM
Motobrewmaster's Avatar
Motobrewmaster Motobrewmaster is offline
Here is the modifications I did to my Ricks tank vent locations. See the attached pictures.
69 Camaro Owned since 1984.
Oh and Yes I am a Brewmaster.
