Old 03-03-2017, 12:57 AM
Btamayo23 Btamayo23 is offline
There is a flange you can buy that bolts up to the 3 bolt flange on the cts v t56. You can have youd local driveshaft shop make you a slip driveshaft i believe the yoke is a 1350 so its pretty beefy. Just another way to go about it. I have a complete drivetrain from an 05 CTS V so I've done a little research.
Old 03-03-2017, 07:41 AM
richs71nova richs71nova is offline
I thought i had seen something like that before on another forum but i couldnt remember. do you know who makes that adapter?
Old 03-03-2017, 09:02 AM
Yes sir its made by The Driveshaft Shop. Heres a link.
http://www.driveshaftshop.com/drives...nger-05-06-gto
Old 03-03-2017, 09:52 AM
Thumbs up
Awesome! Thank you!
Old 03-03-2017, 02:59 PM
No problem
Old 03-05-2017, 05:47 PM
carkrazy1987's Avatar
carkrazy1987 carkrazy1987 is offline
also f-body shaft wont work, because of 2 pcs synchro on f-body. gto/cts-v/and corvette use 3 pcs synchro. f-body and gto shafts are the same length tho.
1960 Chevy C10 Apache
1969 Chevy Nova
2007 Chevy TBSS
Old 03-13-2017, 12:04 PM
gnx7's Avatar
gnx7 gnx7 is offline
You would need a GTO mainshaft as stated to convert it including tailhousing.
That adapter Ujoint part looks pretty slick
