Old 04-02-2017, 05:16 AM
mikels mikels is offline
Originally Posted by 71RS/SS396 View Post
GM also didn't design either one of those cars for sustained high rpm track use. There's a reason why they went to a dry sump for the Z06, ZR-1, and Z/28.
Current and previous generation CTSV and ZL1 had same criteria for track usage that Z06, ZR1 and Z28 as part of their Vehicle Technical Specifications.
Dave
Old 04-02-2017, 06:15 AM
True , guess we're getting away from the op question of using them for forged pistons . The answer is yes most certainly use them wouldn't do any harm . My question would be are they worth the cost of machining and putting them in and how much would the machine works cost roughly
Old 04-02-2017, 06:16 AM
True guess we're getting away from the op question of using them for forged pistons . The answer is yes most certainly use them wouldn't do any harm . My question would be are they worth the cost of machining and putting them in and how much would the machine works cost roughly
Old 04-04-2017, 03:16 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Originally Posted by carbuff View Post
If you want to try a couple of other shops...
Texas-Speed is located north of Austin in Georgetown now. You could contact them.
Also, H-Squared Racing Engines in Houston is doing work for me. Could contact them also.
There are multiple other LS shops in Dallas and Houston that might be close enough for more consultation.
Thanks, I'll check into them.
