Old 05-15-2021, 10:30 AM
572Camaro's Avatar
572Camaro 572Camaro is offline
I love powermaster starters over GM.
I have no experience with LS motors.
I run BBC.
That being said,
My first GM starter was axially offset and no shimming could fix it.
I went with Powermaster because:
1. I can adjust axial offset.
2. I can clock the starter.
3. I can use all three bolts to secure starter to block.
(I just bought a new AC/Delco starter for my zero turn and it has a stamp:
Made in Korea)
Powermaster rules.
Old 05-15-2021, 11:30 AM
dhutton dhutton is offline
For LS engines the factory starters work great and they are affordable. No need to go with anything else imho.
Don
The Following User Says Thank You to dhutton For This Useful Post:
Che70velle (05-16-2021)
  #13
Old 05-15-2021, 10:27 PM
randy randy is offline
Factory starter and heat shield
The Following User Says Thank You to randy For This Useful Post:
  #14
Old 05-16-2021, 02:11 AM
Did some quick checking and for the starter the other part numbers are (Saving for as much my information as anyone else):
12617229 ACDelco GM Original Equipment Starter
12101763 Pigtail CONNECTOR
11610787 Starter BOLT Qty 2
11571131 Shield BOLT Qty 3
12629286 SHIELD
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
The Following 3 Users Say Thank You to will69camaro For This Useful Post:
camcojb (05-16-2021), Che70velle (05-16-2021), Spiffav8 (05-16-2021)
  #15
Old 03-16-2022, 02:59 PM
pannetron's Avatar
pannetron pannetron is offline
I realize this thread is old but wanted to add this bit of info. If you're using an early Quicktime bellhousing for a Magnum transmission with a *round* hole for the starter, an LS3 starter may cause some interference to fit. The earlier LS1 starter mounts about 1/8" differently and fits perfectly to both the engine, flywheel, and bellhousing. Later Quicktime bellhousings have an oval opening for the starter so the LS3 starter will fit, no problem.
The Following User Says Thank You to pannetron For This Useful Post:
TT302Z28 (01-02-2023)
