Old 12-12-2017, 12:21 PM
Blake Foster's Avatar
WE are working on a Billet steering arm / bump steer kit that will hopefully solve this issue.
it will use a 5/8 heim outer and a long ti e rod sleeve.
the problem is. we can only move the steering arm so much. and there is alot of different rim profiles. PLUS as you increase the back space the rim gets smaller ID. also you need to realize that the Sway bar becomes the limiting factor on the back space.
with a stock sub an stock (replacement) sway bar i would be surprized if you could fit much more than 5.5 bs wheel on there.
there really is only so much you can do.
Something about 5 lb of S%$t in a 2 lb bag.
Blake Foster
www.speedtechperformance.com
Old 12-12-2017, 03:53 PM
v8s only's Avatar
v8s only v8s only is offline
I had a similar problem installing a washer between the spindle and steering arm
solved my problem.
Tony
68 Camaro pro touring sold
69 Camaro pro touring for sale
62 corvette pro touring sold at barrett jackson
Old 12-12-2017, 08:56 PM
F'in mine's Avatar
F'in mine F'in mine is offline
The Z-28 steering arms are #3902519 LH, #3902520 RH and shorter in length. If you can find them they're pricey.
1969 Camaro SSRS
Simon
Old 01-03-2018, 07:15 PM
frojoe's Avatar
frojoe frojoe is offline
I had to spend about 6 months of constantly checking eBay before I found a set for myself, didn't even find them by searching part number (listed as "Camaro z28 steering" or something like that instead) but I was able to zoom in on one of the pixelated pictures and read the part number on one of the arms.
Joe
1972 Nova with twin 6466's and T56 Magnum in the works. Speedtech, Ridetech, Wilwoods etc. Swap thread --> http://ls1tech.com/forums/showthread.php?t=980909
Old 01-05-2018, 12:41 PM
Moabdude's Avatar
Moabdude Moabdude is offline
Thumbs up
I have the Z28 short steering arms. They came with the car :-)
I solved the problem by adding a 1/2" spacer between the spindle and the steering arm.
Also the rotor hat is 1/4" thick and that gives me extra space.
So I am fine now
>68 Camaro pro touring, 400SBC, 18" Intro's, T4 13" Baer Eradispeed, Airride, Speedtech, Autometer, König seats, March, Magnaflow. Hope to finish in 2006...2007...2008…2009...2010...2011...Yes, 2012 and its finished (well, will it ever be finished )
>69 Nova project, LS1/4L60e, Corvette C5 calipers+rotors, AFX spindles, 69 Camaro body mods, Just got it painted.
Old 01-05-2018, 02:31 PM
nicks67ca nicks67ca is offline
I may have a set of the SHORT LH-3902519 RH-3902520 turn stop pad is more pronounced on top. I am running a speedtech pro touring subframe with the rack and pinion that requires the unisteer arms. I had someone else interested but they are not sold yet.
