Old 08-22-2006, 07:27 AM
Streetking's Avatar
Streetking Streetking is offline
Thanks guys. I will let you know if I do get this car.
SW
Old 08-22-2006, 10:01 AM
Reckley's Avatar
Reckley Reckley is offline
Unless the rest of the car is perfect and you are getting a great deal, I would avoid a car with undercoating. I just stripped undercoating off the bottom of my camaro. Yes, you can use solvents and heat to remove it however, it gets into every little corner and crevice. It's a very labor intensive pain in the butt to get everything down to clean metal. It also gets all over the shop. I know I'll never go through that again
Good luck
Mike
Old 08-22-2006, 11:16 AM
rwhite692's Avatar
For the thick portions, heat gun and scraper to get the thick stuff off. Then, Mr Muscle brand oven cleaner (it is designed to work on a cold oven), and the big, gnarly heavy-duty scotchbrite pads + lotsa elbow grease. Try to let the chemicals do most of the work, tho.
Have plenty of cold beer on hand.
Godspeed.
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 08-23-2006, 08:39 AM
almcbri's Avatar
almcbri almcbri is offline
grinder with a wire brush connected to it. Not sure the actual name, wire wheel?
time consuming, but I have had good luck.
