Old 11-27-2018, 08:43 AM
dgroover4 dgroover4 is offline
Default Need help with LS3 swap in 69 camaro
I have a 69 camaro with ridetech coilover suspension and tru turn kit on stock subframe. Installing an LS3 and tr6060 from 2011 camaro. What oil pan do i need? What motor mounts and headers fit? Thanks
Old 11-27-2018, 09:37 AM
Sales@Dutchboys's Avatar
I would suggest going to Holley.com
They offer a ton of swap products. If you select 1969 Camaro it will show about everything that you need!
Just make sure you select parts for a stock sub and not a dse frame etc..
dutchboyshotrods.com
269-823-2967
The Following User Says Thank You to Sales@Dutchboys For This Useful Post:
dgroover4 (11-27-2018)
Old 11-27-2018, 03:10 PM
AU Doc AU Doc is offline
I'd second that. You'll be money and time ahead to use as many of the Holley components as you can.
The pan, the engine mounts, headers, and exhaust all work together. They have a crossmember for the T56, but I'm not sure how (or if) that would work with the TR6060. When you use the mounts and crossmember together, it also takes care of the driveline angle (though you may have to shim the rear). With the 6060, you may need a CV shaft, which will negate driveline angle issues all together.
Obviously you can mix and match all those parts from different vendors, but then you'll have to work out any issues that you run into.
The Following User Says Thank You to AU Doc For This Useful Post:
Old 11-27-2018, 04:42 PM
DT69Cam DT69Cam is offline
Def go with the Holley/Hooker set-up. Everything fit perfect for my LS3 swap.
69 Camaro Convertible (LS3/TKO in the works)
The Following User Says Thank You to DT69Cam For This Useful Post:
Old 11-27-2018, 05:37 PM
Which Holley oil pan did you go with? 302-2 or 302-3?
Old 11-27-2018, 07:57 PM
Stock f body pan and ats speed tech mounts .. or dirty dingo
The Following User Says Thank You to XLexusTech For This Useful Post:
