Old 02-01-2020, 11:32 PM
rixtrix1's Avatar
rixtrix1 rixtrix1 is offline
Originally Posted by WOLF1732 View Post
If you have a speedway engineering floater you need to go with option 1
s
As a side note make sure you use a solid bearing spacer to lock the bearing pre-load.
In alum hubs this a must you "might" get away with not doing it on steel hubs.
X2 on the bearing spacers! Well worth the $120 or so as the bearings will run extremely cooler with much less drag. I've seen 80-100F cooler with spacers on an oval track car; difference in drag can be measured with a inch/pound torque wrench much like checking pinion preload. This was on several Speedway Motors full floaters, but I doubt if there was much difference from a Speedway Engrg one. All had Winters steel hubs.
Ric
2002 S-10, Daily Driver and autoX
1966 Chevelle MALIBU ( mine since 1971) Drag car converting to a track car!
The Following User Says Thank You to rixtrix1 For This Useful Post:
Goosesdad (02-02-2020)
