Old 10-18-2021, 03:58 PM
Lonnie's Avatar
Lonnie Lonnie is offline
Same here... the TKX has a similar feel to a T-56 Magnum, with smooth shifts at 7000rpm.
I'm pleased, and do not miss the Muncie transmission at all.
The Following User Says Thank You to Lonnie For This Useful Post:
68454RS (10-19-2021)
Old 10-19-2021, 08:03 AM
68454RS's Avatar
68454RS 68454RS is offline
1968 Camaro with a 454ci, 3:55 gears, 26.68 diameter tire (possibly going to a 27.15 in the future)
Right now with the Muncie M-20, I'm turning 3200rpm at 70mph. Staying with the 2.87 fist gear, What OD ratio would you suggest?
If my math is correct;
.81 should put me at 2592 rpm @ 70mph
.68 should put me at 2176 rpm @ 70mph
This is just a cruiser car and I have a lot of long straight roads around me. I do a little auto X and would like to cruise comfortably on the interstates.
Old 10-19-2021, 06:33 PM
Lonnie's Avatar
Depends on how low of an RPM the car will tolerate.
Cam choice is a big factor.
Can you drive the car smoothly at 2000 rpm in 4th?
What is the lowest it will tolerate?
What speed do you drive the most & how often to you like to shift?
My car has 4.10's & does not like to be under 2000rpm, (it idles at 1300) so I chose the .81 & can now drive it in 5th at most speeds over 45.
It keeps me from shifting constantly, and I did not intend on a long distance highway car though.
Old 10-20-2021, 07:20 AM
68454RS's Avatar
Maybe a 6 speed with .80 and .63 would suit me better
Old 10-21-2021, 02:03 PM
Lonnie's Avatar
That is ideal as long as you are willing to deal with potential floor modifications as the T-56 is much bigger.
68454RS (10-22-2021)
