Old 12-05-2020, 08:07 AM
Default Driveshaft .. a judgment call.
Pre prerequisite. current power .. 495 Hp and 473 ftLbs torque.
Likley in the future.. magnuson supercharger and cam swap. target 640 ish HP.
Problem.. my 9 inch has a 1310 yoke...
Option 1 just order the 1310 driveshaft it will be fine at 600 Hp/Tq numbers .. Lots of folks are running this says the all might internet..
Option 2 order an 1350 shaft then install a "hybrid joint"
will require a new pinion yoke which may not be the same length and make shaft useless ..
Options 3... change pinion yoke now.. (not sure if on a 9") this-is just a replace or could impact bearing load ect.. and order a 1350 shaft.. now..
