Old 03-13-2005, 08:25 PM
camcojb camcojb is offline
Originally Posted by BillyBobL71
That is going to be one good looking hunk of aluminum. What did you use for a rotating assembly?
Billy Bob
Scat crank and rods and Diamond custom pistons.
Old 03-14-2005, 06:21 PM
Blown353 Blown353 is offline
Jody, what happened with the GM heads? I thought one of Ross's goal was to "Keep his GM car all GM."
Then again the AFR's are a HUGE step up in terms of flow.
1969 Chevelle
Old 03-14-2005, 06:25 PM
Probably 75-100 HP above what he had. The GM (Edelbrock) heads have a funky chamber shape and many pistons don't fit. His would have required major work to make them fit, so he and I talked and thankfully he ended up selling the GM heads and buying AFR's.
Old 03-15-2005, 05:12 PM
hapevo hapevo is offline
Default thanks Jody!
It is sure nice to see some real progress on the ZL-1! It has been pretty crazy I must say with all of the "problems" that have reared their ugly heads . And major thanks to Jody for putting up with me and that big pile of aluminum!
Ross
Old 03-15-2005, 05:15 PM
Ross
We'll see if you still like me when you get the bill!
Old 03-15-2005, 05:29 PM
907rs's Avatar
907rs 907rs is offline
Welcome back Ross.
Bill
Old 03-15-2005, 06:00 PM
Jody - I knew that was coming!
Bill - Finally found a minute to actually type a few words instead of lurking around.
