Old 04-10-2024, 03:23 PM
69hugger's Avatar
69hugger 69hugger is offline
All great points.
As I just bought the vehicle and have hardly driven it yet, I am going to give it some miles before I commit to a major redo of the system. A couple different mufflers I could see doing. But a more major change will probably have to wait.
Thanks for your input.
Bill
'69 Camaro / 534 BBC / DSE Built
'67 C10 / LS-3 w/Magnuson / Roadster Shop Chassis (SOLD)
'71 Blazer / LT4 / 8L90 / Roadster Shop Chassis / Ride Tech Air Susp.
The Following User Says Thank You to 69hugger For This Useful Post:
camcojb (04-10-2024)
Old 04-10-2024, 05:50 PM
I completely forgot about asking where and how the exhaust exits. That's a great point. Does it go past the axles and exit past the body or under the body?
Old 04-11-2024, 01:49 AM
srode1 srode1 is offline
Originally Posted by 69hugger View Post
All great points.
Borla Pro XS swap would be your easy to try swap, and would give me a nice preview of how they will sound on mine if you do it!
The Following User Says Thank You to srode1 For This Useful Post:
camcojb (04-11-2024)
  #14
Old 04-11-2024, 03:59 AM
69hugger's Avatar
The exhaust goes full length out the back, under the bumper.
Bill
The Following 2 Users Say Thank You to 69hugger For This Useful Post:
camcojb (04-11-2024), WSSix (04-11-2024)
  #15
Old 04-11-2024, 09:46 PM
67_camaroRS's Avatar
67_camaroRS 67_camaroRS is offline
wow here i am, thinking magnaflow mufflers were too quiet. Borla ATTK hit the spot.
1967 Camaro RS
1969 Camaro coupe
Old 04-12-2024, 05:57 AM
PTAddict PTAddict is offline
I had a complete 2.5" magnaflow exhaust system on my 67 Chevelle 'vert with a stock LQ9 (hi-po truck LS). It was too loud and droned obnoxiously between 1500 and 2500 RPM. I replaced the Magnaflow mufflers with DynoMax Super Turbos - much quieter and the drone is almost gone. Hard to exaggerate the difference.
Latest car: https://lateral-g.net/members/borduin/
EFI Tuner for: http://www.modernclassicsauto.com
The Following 2 Users Say Thank You to PTAddict For This Useful Post:
69hugger (04-12-2024), camcojb (04-12-2024)
  #17
Old 04-12-2024, 12:39 PM
71OLDS's Avatar
71OLDS 71OLDS is offline
another vote for DynoMax Mufflers. I have them on my 468 Olds motor in my 71 442 with 3" pipes and they are fairly quiet until you go WOT. Here's the details including the part #s on the mufflers:
Hooker SuperComp Jet Hot coated 1 7/8" tubes, 3 1/2" collectors, into a 3 1/2” down to 3” reducer, into a 3” X crossover, into 3” in Dynomax Ultra Flow welded Mufflers(17229), into 3” tail pipes, into 3” Olds trumpets
Joe Lincoln
1971 Olds 442 Convertible & 1970 Cutlass Supreme
The Following 2 Users Say Thank You to 71OLDS For This Useful Post:
  #18
Old 04-13-2024, 04:53 PM
Just to note, the Dynomax Super Turbo is a quite different design than the Ultra Flow. The Ultra Flow is a "straight through" design, and will likely be a fair bit louder than the Super Turbo.
69hugger (04-14-2024), camcojb (04-13-2024)
  #19
Old 04-15-2024, 09:57 AM
X.K5 X.K5 is offline
Blazers were known to have exhaust fume problems running them strait out the back, gets sucked under the tailgate and hatch, if you have it on. Maybe somebody else knows if a turn down on the end would help..
The Following 2 Users Say Thank You to X.K5 For This Useful Post:
69hugger (04-15-2024), camcojb (04-15-2024)
