Old 01-12-2025, 02:10 PM
ULTM8Z's Avatar
ULTM8Z ULTM8Z is offline
Parts seem to intermix pretty well. They did their math right on the scale at least. Some minor mods and it should be good.
My actual engine for reference. I may use a piece of black wire to form a cold air tube... lol.
The model is LT1 so there will be some differences, but most people mistake my Miniram SBC for a LT1 anyway.
The Following User Says Thank You to ULTM8Z For This Useful Post:
camcojb (01-12-2025)
Old 01-12-2025, 02:33 PM
ULTM8Z's Avatar
Lol... cold air tube...
Old 01-12-2025, 06:01 PM
ULTM8Z's Avatar
Figured I'd make a set of spark plug wires to try to convert this LT1 into a SBC...
Pulled some strands of copper wire out of some 12 awg wire. Soldered them together where they go on the cap. Then found a piece of plastic to represent the distributor cap.
Old 01-12-2025, 06:02 PM
ULTM8Z's Avatar
Grill...
ULTM8Z's Avatar
Re-purposed the starter motor out of the '71 kit into a Sanden A/C compressor... lol... then grafted a portion of '71 belts/pulleys on.
Old 01-13-2025, 07:54 PM
ULTM8Z's Avatar
Getting close finishing! Engine is in... had to modify the oil pan and the transmission tail housing to get it to fit... The HEI distributor and plug wires came out pretty cool too I think.
I'm not going to pay that much attention to the under carriage. The model will spend it's entire life right-side up.
Old 01-13-2025, 07:55 PM
ULTM8Z's Avatar
I decided to run with the Corvette steering wheel. Neither is a match for my Momo wheel, but the Vette looks more updated...
Old 01-13-2025, 07:56 PM
ULTM8Z's Avatar
The '71 fan shroud without the fan is a pretty good approximation of my Taurus electric fan
Old 01-13-2025, 07:57 PM
ULTM8Z's Avatar
Glass is in and some detail on the master cylinder and booster.
camcojb (01-14-2025)
  #20
Old 01-14-2025, 06:54 PM
ULTM8Z's Avatar
Body on chassis finally...
I had to break the alternator and A/C off and lower them a bit as they were hitting the hood.... funny that wasn't the case on my actual Camaro... hmmmm.....
I'm going to have to offset the wheel centerlines from the axles a bit in order to set the ride height. Also, as in real life, the offset on the Vette wheels is too deep... lol... I'll need some 1/25 scale wheel spacers.
camcojb (01-15-2025)
