Old 03-27-2005, 06:38 PM
radrambler's Avatar
Default its hard
Originally Posted by Ummgawa
Keep rubbin till its hard Rad. Great Job!!
body work sucks ......its all hard labor...
Old 03-29-2005, 02:35 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
Day one on the books. Spent all day Monday guide coating and blocking. Came up with a couple dozen low spots. Washed the car down and slid it back in the garage and started the two part putty coating and 17" board with 180 dry on those spots. The rest of the car is a combo of 220 wet and 400 wet depending on the surface.
Guide coating will really help bring things to the surface that you would not otherwise catch until it had the clear coat on. By then it is too late. Today is going to be CRAZY as we have to run all over town as well. It is 5:30 a.m., heading out there now. Going to wrap up the putty coat, tape and paper it all back up and put two more wet slick coats of primer on. Will let that set out in the sun today and will shoot a guide coat on tonight.
Wed will be a repeat of today but it will take longer to go around as I will be cutting it with 500 per the PPG material data procedure.
I am debating if I will wait to put the sealer on just before the top coat, or do it now and block it down. I want to make sure none of the old material that had been used by the lousy body shop that had installed the quarters bleeds through. I suspect some laquer products were used between layers of filler on the sail panel bonding surface.
My arms already feel like they are going to fall off!
Old 03-29-2005, 04:48 PM
69MyWay's Avatar
It is a little more than 12 hours later since I last checked in.
Re-primed the car and re guide coated.
Hitting it with the 500 wet in the morning and hoping this is the last go around.
Here is what it looked like on Monday.
Old 03-29-2005, 06:02 PM
jonny51 jonny51 is offline
Do you or rad sleep?
Old 03-29-2005, 06:30 PM
radrambler's Avatar
Default sleep?
whats that jonny? lol sleep????....
chris and i are on a mission...hes shooting for goodguys columbus..and myself the power tour..hes in the lead on progress...
GO CHRIS
radrambler
Old 03-29-2005, 06:49 PM
You guys are both kicking ass on your projects
Old 03-29-2005, 10:35 PM
awr68's Avatar
awr68 awr68 is offline
Chris since you're on a roll, why don't I bring mine over!!
Looks great can't wait to see the next pics!!!
From what I understand, you want to put the sealer on right before you start with the color...ya know the same day.....but I'm sure every manufacturer has a different window?
Tony
'68 Camaro
Old 03-30-2005, 02:03 AM
69MyWay's Avatar
You are correct. This is the method when it is not sanded, or otherwise called wet on wet. I am debating still. It will have much to do with what it looks like after I finish the 500 wet sand on it today as to whether or not the sealer will go on now.
One plus about doing it now is I can then feather edge that paint line at the jam edges before the color shot. Therefore the color tape edge will be minimal. When you do sealer and color the jam paint edge has a larger ridge and sometimes you can see the faint grey sliver on the tape line.
Old 03-30-2005, 06:08 PM
radrambler's Avatar
Default go chris
hey bud
got to shop and worked another hour TONIGHT blocking down left qtr....then swipped it again..guess... ill block that off tommorrow......I HATE BODY WORK!!!!!!!
CAINT WAIT TO GET PAST THIS STAGE.......
.WHEELS ON SCHEDULE FOR TOMMORROW FROM UPS!!!!
YOUR KICKING BUTT ON THE PAINT.....
.CALL ME TOMMORROW let me know how your doing with it.....
later
radrambler
Old 03-30-2005, 06:13 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Rad
What are the wheels you are going with?
Jim
