Old 12-14-2006, 09:38 AM
camcojb camcojb is online now
Originally Posted by 3kidsnotime
Jody do you have a pic of what you want built? and a old part to splash (copy for mold) and a close up pic of the carbon fiber grain or oz you want to match on your dash.
The console is metal and is not reproduced. They all have chips and wear in the center areas with tiny ribs. This is a pic of the rear section and you can see the two areas across the top with the ribs. Although they look fine in the pic in reality they have a lot of knicks in them. So since I have the dash and glovebox piece I thought they would look awesome in the top areas of the console, probably with the console powdercoated black.
Not difficult to make but the front section curves down over the front of the console, so those pieces aren't flat either.
Originally Posted by CraigMorrison
www.carbonguy.com
He did all of the carbon work for us on the Vette. Good guy, great work.
thanks Craig, need all the help I can get.
Old 12-14-2006, 09:59 AM
3kidsnotime's Avatar
3kidsnotime 3kidsnotime is offline
So your thinking just the ribbed area, have a carbon insert? Are you going to mill the ribbs down for the carbon to sit flush?
Old 12-14-2006, 10:19 AM
Just the ribbed area. There is a lip around the area. I was hoping to just attach the carbon fiber pieces over it, either with silicone or 2 sided tape. Milling would be a pain.
Old 12-14-2006, 01:29 PM
How high up is the edges from the rib, that will have a factor on what ounce material you can use for laminate, to sit flush with the raised area, also the easiest way is to take a mold off the top of your console to do the laminate of carbon. Let me check I might have a friend with a 65 console I can get a better look at it that way.
Old 12-14-2006, 02:42 PM
slow4dr's Avatar
slow4dr slow4dr is offline
Jody, these guys have been real good to the SRT community. I am not sure if they'd be interested in custom goodies or not but it's worth a try.
http://www.carbonbydesign.com/
'04 IS300 LS3/TR6060 swap in process
'89 Plymouth Colt GT - 411WHP, 2490lbs & 32mpg
'06 Magnum SRT8 - AFE S2, 3" Flowmaster catback, Diablo Predator (KIA by a drunk driver 10-25-13)
63 Nova 'Low Budget G-Machine' *SOLD*
Old 12-14-2006, 03:02 PM
.075" or so, but it could stick a little above without issue. Here's a couple more pics. I can ship the console to whomever to make the pieces.
Old 12-14-2006, 03:03 PM
thanks Jason, I'm checking with the first two mentioned first as they do custom stuff, but I appreciate the info.
Old 12-14-2006, 04:09 PM
Fluid Power's Avatar
Default Carbon Work
Jody,
Alex at wolfdenproducts does incredible work. They do all the CF for Rahal, Michael Shank racing and bunch of other car guys here in town. They have also done a bunch of work for Honda as well. (there is a huge R&D facility not to far from Columbus)
http://wolfdenproducts.com/
Darren
Old 12-14-2006, 04:50 PM
Well you would want to bolt the console together amd make a mold and do a laminate in one piece then trim it to fit the inserts so the grain will flow from side to side and also rear section to front, do you want the grain on a 45 or 90, how soon do you need it?
