Old 02-10-2007, 07:42 AM
68sixspeed's Avatar
68sixspeed 68sixspeed is offline
Kurt- thanks- were the gaps any better than the goodmark? it would be well worth the extra cost if the gaps started out right or close to right. -Dan
68 Camaro RS/SS, Katech tweaked LS7/t56 magnum
68 Camaro RS Convertible Project
2006 Corvette Z06
2011 Corvette grand sport convertible
Old 02-10-2007, 08:18 AM
Lenie's Avatar
Lenie Lenie is offline
Thanks Frank, I'll use your advice. I'll let you know how it goes.
Old 02-10-2007, 08:20 AM
Lenie's Avatar
Chris, it's under 68 firebird 400, sorry for the mistake
Old 02-10-2007, 05:48 PM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
The gaps were indeed better but the problem I had was the crown was not consistant with the rear body panel. Nothing some tweaking couldn't fix.
Old 03-03-2007, 07:07 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Originally Posted by ProdigyCustoms
Lenie, it is always better from a warpage and potential damage standpoint to build a compound edge like the 90 degree quater panel to trunk jam edge, then the thin highly warpable edge of the deck lid. A bead of tig or mig alog the quarter jam area is not going to do a bunch of damage. And it if does you are fixing a area 5 inches wide. If you warp the edge of the deck lid, which you will, you have now got 48 inches to straighten and make flow.
Now here is where the problem comes in though. If you do the quarter jam, you need to be sure left and right jam throths are even size when your finished. Just recently I saw a car and it was obvious the left troth was 1.25 wide and the right 1.5 or somethng like that.
Also, the same theroy would apply to quarter to door gaps also. Do it everyday.
Franks, can you explain a little more or send some picks, I should be fitting my deck lid next week. Almost done the 1/4 panels now.
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
