Old 04-09-2007, 12:07 PM
Steve1968LS2's Avatar
Originally Posted by XcYZ
Steve, that's what I was thinking - the LS would change the sound a bit. I've done the Flowmasters, but I want to do something different. Spintech's are at the top of the list... with that said, I'd like a more late model sound. Something like the way Sandlin's Procharged ZO6 sounded at SEMA.
The Spintechs will be more "raw and in your face" the Maganflows will be more "OEM refined performance"
I'm running 14" Magnaflows with a 3-inch x-pipe
Old 04-09-2007, 12:12 PM
Blown353 Blown353 is offline
Anything straight through and packed is the way to go IMO... they will have the least resonance, be quietest during light-load, and the best flow.
Borla XR1 (great mufflers in all aspects... unfortunately they are limited for inlet/outlet configurations and they don't make a config to fit my car which is the only reason I'm not running them.)
Magnaflow
Dynomax Ultraflo
Spintechs sound pretty nasty and turn heads-- a couple of my friends run them only for the sound. However, several guys on another message board making big power have made more power switching from Spintechs to straight through packed style mufflers.
I used to run Ultraflo's but they cracked on me and I switched to Magnaflow. I really like them both for sound and quality-- and their case profile being devoid of flat surfaces will be more resistant to bloating/cracking as my Ultraflo's did.
1969 Chevelle
Old 04-09-2007, 12:49 PM
TopEndeR TopEndeR is offline
My brother as dynomax ultra flows on his procharged 357 small block. They sound great. When cruisin they are very quite so you can hear the radio . But when he's at full WOT it sounds like a jet airplane is going by you
Old 04-09-2007, 01:00 PM
71Nova 71Nova is offline
I love my ss magnaflows. I get a lot of complements. Strait threw design.
David
Old 04-09-2007, 01:16 PM
Jimmy Sean's Avatar
Jimmy Sean Jimmy Sean is offline
Originally Posted by camcojb
He's not running turbos (at least for now! ). I've always had good luck with ultra flos.
Well some reason I thought he was, maybe the old motor?. With that said I always had received good comments with my Spintech mufflers on my suburban. My only complaint was trying to hold a conversation on the highway was a bit tough, just depends on what you want.
Old 04-09-2007, 01:26 PM
Jimmy Sean's Avatar
Originally Posted by mazspeed
Sean, as far as I know spintech is one of the most high flow mufflers around, unless there is something you know that I don't? Which is always possible by the way. But as far as I know, they flow more then most.
Just going from what Chicane said in a post about turbos and mufflers.
Old 04-09-2007, 01:39 PM
ArisESQ ArisESQ is offline
ive got borla XR-1 with an X-pipe and couldent be happier.
Old 04-09-2007, 01:45 PM
67ragtp 67ragtp is offline
How about Stainless Works, nice quality stuff, sounds good. I believe he has two different mufflers to choose from. Just keep in mind killer loud can get pretty monotonous on the long haul, if you plan on extended cruising.
Rich
Old 04-09-2007, 03:06 PM
69 L88 Camaro 69 L88 Camaro is offline
Default Muff
Went from Flowmaster to Spintech and lowered interiour noise quite a bit. Also Spintech came in every configuration and were thinner than the Flowmaster. Had a good price too. Talked directly to Spintech.
I don't ride in it, I drive it.
Old 04-09-2007, 05:23 PM
Lateral-g Moderator
LS7, Cam, Headers, 3", X pipe, any of these choices will sound great. Cool car.
